Silverado True North edition?
a used car lot about an 1hr from has 3 True North editions on their lot.
all 3 are LT Z71 models & have large True North badges on the doors. 2016 & 17 model years
they are each a different color.
1 is a 5-seat w/ JB1, 1 is a 5-seat non-JB1, & the other is a 6-seat w/ JB1.
Does anyone know exactly what is included w/ this package? w/ a name like that, one would think: rear defrost, heated seats, remote start (all of which are on all of the LT Z71's that i've seen so far), maybe a larger alternator, larger cca battery & a block heater? but alas, i cannot find anything.
i can find a dealership called True North & several videos on youtube from dealerships in Canada that mention True North, but door badges or specific mention of the package includes.
https://www.richardsmotorcars.com/details-2017-chevrolet-silverado_1500-4wd_crew_cab_153_0_lt_w_1lt-used-3gcukrec1hg266752.html
True North is the Canadian market equivalent of the AllStar package in the states.  Same options in the package, same RPO code "PDU" just a different name.
True North from the 2018 Canada order guide:  https://www.autopartners.net/apps/eogld/NASApp/domestic/proddesc.jsp?year=2018&regionID=14&divisionID=1&type=0&vehicleID=21128&section=oi_def&page=4&butID=3
Quote
True North Edition, for Crew Cab and Double Cab includes (AG1) driver 10-way power seat adjuster with (AZ3) bench seat only, (CJ2) dual-zone climate control, (BTV) Remote Vehicle Starter system, (C49) rear-window defogger, (N37) manual tilt and telescopic steering column and (KI4) 110-volt power outlet.
1 - Includes (Z82) Trailering Package, (G80) locking differential and (T3U) LED front fog lamps. Not available with (NHT) Max Trailering Package or (PCM) LT Convenience Package. If (LV3) 4.3L EcoTec3 V6 engine is ordered (N37) manual tilt and telescopic steering column will not be included.
2 - If (LV3) 4.3L EcoTec3 V6 engine is ordered (N37) manual tilt and telescopic steering column will not be included.
Allstar from the 2018 US order guide:  https://www.gmfleetorderguide.com/NASApp/domestic/proddesc.jsp?year=2018&regionID=1&divisionID=1&type=0&vehicleID=20987&section=oi_def&page=4&butID=3
Quote
All Star Edition, for Crew Cab and Double Cab, includes (AG1) driver 10-way power seat adjuster with (AZ3) bench seat only, (CJ2) dual-zone climate control, (BTV) Remote Vehicle Starter system, (C49) rear-window defogger, (N37) manual tilt and telescopic steering column and (KI4) 110-volt power outlet.
1 - Includes (Z82) Trailering Package, (G80) locking differential and (T3U) LED front fog lamps. Not available with (NHT) Max Trailering Package, (PCM) LT Convenience Package or (PDA) Texas Edition. If (LV3) 4.3L EcoTec3 V6 engine is ordered (N37) manual tilt and telescopic steering column will not be included. Wheels will be replaced with (RX1) 22" LPO wheels when (PDD) Local Market Package (Double Cab), LPO or (PDD) Local Market Package (Crew Cab), LPO is ordered.
2 - If (LV3) 4.3L EcoTec3 V6 engine is ordered (N37) manual tilt and telescopic steering column will not be included. Wheels will be replaced with (RX1) 22" LPO wheels when (PDD) Local Market Package (Double Cab), LPO or (PDD) Local Market Package (Crew Cab), LPO is ordered.
these 3 trucks that I found are in Massachusetts, not Canada. Their clusters are MPH, not KPH. But I get the jist of it. Thanks for the reply though.
In my 2018 you can easily change between units.  The analog speed gauge always displays the correct speed as well.  It's not like in the past, where you had the "foreign" units in smaller numbers that you had to try and read.
ahh, ok
my newest compact truck was an 01 Sonoma cc, my newest fullsize is a 99 c3500 cclb (getting retired for a newer model) & a 99 Suburban. I skipped on both the 800 & 900 models as they didn't interest me. the t1 also doesn't appeal to me.  I honestly never thought to see if my Charger could display both sets, now I gotta look & see.
All three were probably shipped from Canada and bought at auction.  Switching from metric is a user friendly feature.  I switch to mph whenever I cross the border for a visit!   The difference in the dollar make it worthwhile to sell used Canadian vehicles in the US.
Its Canadian.  Has RPO code Z49 on the build which is the identifier for Canadian Market.  We bring GMC's down from there quite often.  Do any of them have a 200mph speedo?  If so they just switched the units readout to English.  Another giveaway is there is no E or F on the fuel gauge, coolant temp is different too.  If they put a US cluster in it and has the 140mph speedo, the DIC fuel mileage bests will be like 31mi, 62mi and 455mi instead of 25mi, 50mi and 400mi.
The VIN of the truck in your first post was a Canadian truck when new.  The very last pic of the door jamb sticker is in English and French.  Going through the service history of it, it was originally sold in Newfoundland.  Had all service work done up there up until it came to the US.  Dealer did the recalls on it 10/25/2019 so they must have just got that truck in not that long ago.
Isn't a Texas Edition the same as an All Star also?
Another thing I always wondered about the Mexican Silverado Known as the Cheyenne. Does the cluster read in Metrics and is it in Spanish? My guess would be yes but I have no idea.
14 hours ago, Mars2878 said:
ahh, ok
so, i checked the Charger last night, the analog gauge is like all others that i've had, mph larger on the outer edge w/ kph smaller on the inner edge. the digital screen also has a speedometer on it & allows me to toggle between the 2. so i learned something new on the car.
in New England we have to contend w/ rot from road salt, would these Canadian trucks be any worse for wear? I ask because i don't know what Canada uses to treat its roads.
They might have seen worse.  Hopefully one of our many Northern users on here can chime in but some Canadian provinces use sand with liquid chemical mix.  Pretty rough stuff.  I've seen some 2018's come down from Quebec that have more surface rust and missing wax than an NY state truck that's been on the road since 2015-2016.  And NY is pretty heavy on the salt in some towns.  Especially if its a mild winter.  They make sure to use the allotted salt budget LOL.
Yes, if they are from Ontario, walk away. If they are from the prairies, MB, SK, or AB they wont be in bad shape. In Ontario, you can buy a brand new K2 and have the frame look like its 20 years old after one winter. The NOX rust frame coating just cant hold up to the magnesium chloride here. I would recommend wearing some Sunday sweat pants and crawl under each truck to inspect for corrosion.
You have to inspect any used vehicle carefully.  Signs of premature rusting is a red flag no matter where the vehicle was sold originally.  Unless we buy privately from a close friend, we can only guess about the history of a used vehicle.   Knowing where its previous owner lived is interesting but doesn't tell us how it was maintained.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
