Has anyone purchased and installed this keypad?  Wondering if it works if the key fob is left in vehicle to keep the truck running instead of turning off after the predetermined set time.
Curious about this.
I leave my truck running often in the hot summer or cold winter as I bring my dog with me everywhere and he stays in my truck when I do site visits. I hate how the truck turns itself off.
Interested myself. I can't find any info on this online other than a GM-authority article. Does anyone know if this is wireless and just sticks on or how its installed?
Edited by bharris515
I was keeping an eye on this device as well. This is copied from shopchevyparts.com
Designed for mounting above the door handle on the driver side, this keyless keypad can be placed on any blemish-free glass or painted surface on the vehicle. Forget the magnetic "hide-a-key" and use this Remote Keyless Keypad to unlock the doors securely.  Think digital "hide-a-key".
I have this.  I know you can lock the fob inside the truck with it, which is what I wanted.
Not sure about keeping the truck running and wasn't even aware that the truck would shut itself off after some time.  I never let mine just idle for any amount of time.
It is a neat little device.  Dealer had to program it to the truck, then yes it just double-stick tapes wherever you want it on the truck.  It does seem a bit cheap and fragile so I do wonder about how long it will last, but so far so good.
first person i have heard with this on . got a pic? i like my ford work car with that on it - never take keys out
Hmm now I wonder if it would survive the automatic car wash over time...
Wonder if you could stick it to the inside of the gas filler door? Then you run the risk of the gas fumes messing it up or the double stick tape. ?
I can snap a pic, but like Steve mentions, I have yet to mount it due to concerns about how it will hold up to the Ohio Winter.  I did consider inside the gas door, and that may / may not work as it looked to be a really tight fit.  My thought was to mount it in the area where the mirrors are mounted on the older trucks - keeps it hidden as I think it sticks out too much if you mount it on the B pillar.  I had a $100 accessories credit, so it only cost me $100 including dealer programming.  In hindsight, just not sure it was worth it as it looks to be disposable after 18 months - maybe I am wrong, but it just does not exude quality or resilience in my opinion!
Thanks for the input. I think on the door where the previous mirrors mounted would be the safest place. I'd be curious if you can install it and then run a bead of clear silicone sealant around the outside end of it to seal it to the door panel?
Can you actually lock the key inside? im scared that it might think the key is "near the door" and will unlock if someone tries the button.
Where do you put the key?
Yes, you can lock the fob inside.
Agree, I checked tonight and you can lock the fob inside. The GM pic shows the front well, so I snapped a pic of the back for you.
I just ordered one of these. I’ve always thought that was a good idea when I’d see my friends with Fords use them.
Are they backlit?
Are they backlit?
was wondering same thing. Is it backlit? Also are they physical buttons you press or like a touch screen?
Yes, it is minimally backlit once you press a button.  There are five actual buttons - one in the section marked 1/2, one in the 3/4 section, etc.
You can lock the truck without putting your code in.  Inputting the code unlocks the driver door, you can press an additional button for it to unlock the other doors.  If you hold the buttons, it will fold/unfold the mirrors just like the fob does.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
