So this just happened to me. Fixed itself in 24 hours but still had me upset. It’s still a brand new truck. So hopefully this doesn’t happen again. Any suggestions to keep it from happening again?  A fuse change?
You'll have to contact the dealership to see why the check engine light came on. You have a warranty after all on a new truck.
Take it in and see if they can find the computer has stored the cause of the CEL.
Go to dealer to get reason for code.
FYI--low fuel (warning light on) also will not allow a remote start.  I know this isn't your problem but just wanted to share/add.
I haven't tried remote start with low fuel.
The OM warns against using remote start if fuel is low --- but doesn't include low fuel in the list of things that prevent remote start.
2021 Manual:
Do not use remote start if the vehicle is low  on fuel. The vehicle may run out of fuel.
The vehicle cannot be remote started if:
. The RKE transmitter is inside the vehicle or if the key is in the ignition.
. The hood is not closed.
. There is an emission control system malfunction and the lamp is on.
. The ignition is in any mode other than off.
. The hazard warning flashers are on.
. Two remote starts or a remote start with an extension have been used.
. The vehicle is not in P (Park).
The engine will turn off during a remote vehicle start if:
. The coolant temperature gets too high.
. The oil pressure gets low.
2021 Manual:
I could be thinking of my last truck. I’ll try it next time my fuel light is on.
My truck ended up being able to remote start with low fuel (2020 Trailboss w/ 6.2) so I must of been remembering my Ram.  I would assume that my 2021 Sierra is the same.
Low vehicle battery charge?   Will it affect/disable remote start.   Have a 2019 Silverado Z71.   Key fob batteries are brand new.   Dealership telling me the hood latch may be defective.   I have a hard time believing it would be bad in 3 years.
I have code reader and no codes stored to prevent  a remote start.   When I open and close the hood with the code reader hooked up it immediately reports the correct status of open or closed.
Noticed when remote start does not work and I put the code reader on it and it showed the battery at 40%.    Put optima 400 digital charger on the battery and after the charge and conditioning cycle, the remote start may work twice.     Alternator is charging fine.
plan to replace the oem agm battery on Monday
Update 12-13-2022
The battery was just load tested by an large independent battery manufacturer on 12/13/22 while i watched and they said the battery tested like a new battery.   My concern was the battery may not have been holding a charge even though you could manually start  the vehicle just fine.    The reason I did this was something I found in researching the remote start failure which indicated if the vehicle battery was below a certain charge %, remote start would be disabled.
Update 12-15-2022
Took vehicle in for 3rd visit.    On the 2nd (previous) visit I mentioned to the service tech on 1 occasion I had encountered a brief "hood open" message when manually starting the vehicle but it quickly disappeared.   He was able to recreate the quick false hood open message and even though no codes were generated or stored, determined the hood latch was flakey and needed to be replaced so they ordered one and I went back for a 3rd visit a week later to get the hood latch replaced.   I also had them do an oil and filter change since the weather here is too brutal to do it outside.
It appears the new hood latch has resolved the problem so far and was the old latch was the electronic gremlin cause to all of the other false messages I have encountered.
The dealership said they have encountered a handful of faulty hood latches.
GM/Chevrolet need to examine and redesign the hood latch or switch to a better manufacturer of the part.
 It is bad when the original hood latch which just turned 3 years old on December 6, 2022 failed.
I doubt the hood has been opened and closed more than 36 times in the 3 years (to change oil or to /check oil and other fluid levels at approximately once a month.
The truck just turned 50k and still has the original oem agm battery and the original oem Goodyear Wrangler tires.
I intend to get new tires within the next month.
In any event, will give an update in a few weeks.
P.S.  Posters on this forum tend to run down "dealerships" and their service and prices,   Go find another dealer then.
There is a Chevrolet dealer much closer too me, which I absolutely refuse to deal with or even visit.
So I purchased this vehicle new  in another town and county which is a 35 minute drive for me each way.
The dealer I originally purchased this vehicle from has been fantastic.  They never charged me a dime for the previous two diagnostic visits because they could not fix the problem.
Their tire rotation fee (if you do not have a coupon for a free one) is lower than most other places.   It is why my tires are in good shape at 50K.  They are focused on customer satisfaction.    They do not want you to leave from your service visit unless you can rate them essentially 10 out of 10 (i.e. extremely satisfied).    They did not have a problem or objection  when I asked if I could walk back and discuss the problem with the service technician.   In fact it was one of these discussions which led the technician to suspect the hood latch as the gremlin/culprit.  Due to lack of generated or stored codes, it was the only real source of information for him.
They also gave me the old defective hood latch as I requested.  I will do some testing on it this winter when I get time.
Edited by SteveP45
Update after 3rd service visit to Chevrolet dealership
This is certainly not what we like to hear, SteveP45.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2019 Chevrolet Silverado Z71. To do so, please send an email to [email protected] with ATTN: SteveP45/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
    • I have a 2015 Silverado and sometimes I can not get in to the truck. I use the key to unlock the driver door. Something is locking the truck when I unlock it, last night I left the truck open and this morning it was locked with the mirrors folded in. This happens while driving so it is now a safety issue. I reach down for the folding button and they open, then they close again.  Any advice, thank you,   Ed
    • Did you ever find a resolution to this? my 2019 Silverado 1500 is showing the exact same headlights issues with the exact same symptoms.  would help a ton if anyone has any advice on this or better yet a known solution..
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
