The black also comes with the rear tailgate emblems the red does not
Ah yes, keep forgetting that
Just installed mine this afternoon. Super easy thanks to tips in this thread.  The black version comes with rear black (non-led) logo. I’m not going to install it. If anyone wants it, please message me.
Edited by fc_glk
Added image
How much?
If anyone has one of these they haven’t installed, I’d really like to see the installation instructions and pics of all the connectors on the wiring harness including the wiring colors going into them if visible.  I’d like to see if I can maybe fabricate my own for use with my grill lights.  TIA
lets see, just ordered one from the Chevy parts web site posted in this file....got it in about 5 days with the 4th Holiday in the middle.
Now to the install: spent a lot of time with all kinds of trim tools and small screw drivers, had an extremely difficult time getting the clips on the original GMC emblem to release, no matter how slowly or carefully I worked on them eventually broke a couple of the tabs off the black grill mounting surface, not happy, the only way you can get a replacement for that part is a whole new grill, paint to match by the way, and around 400-500$.... Tried an install with double sided 3m molding tape as an assist, nope, there is just enough curvature in the factory grill that the clips on the new lighted emblem would pull away from either one side or the other, the stock clips would not grab and hold.......OK, so now what???   tried everything I could think of, finally decided that the only way I could get a nice mount was to epoxy the new emblem to its mount, hated to do that, but choices limited!....Thought about tiny screws, but figured soon as I drilled thru the new emblem, I would hit an internal wire or connection and that would be that.......anyway, think its on, epoxy is drying, looks great and works, so overall I'm happy....just hope I never have to try and remove it one day.......
Which trim do you have? I don't think my AT4 has a painted grille.
Its the top the line AT4, the grill looks like it has a black chrome overlay on all the cross bars of the grill, but the part # 84508683, says that there all paint to match.......maybe these elk chrome overlays attach, but I guess the grill might still require paining first....really don't know...anyway kinda stuck now for a while anyway....but its ok, still looks great
I guess you are right. Didn't notice it on mine at first. Many pieces can be ordered pre-painted though so that's dissappointing.
Went to my local dealer and they had them
in stock! Very fast clean Mod that looks awesome!
Does it look that bright in person? I always think other people's looks brighter than mine.
It’s decently bright but I feel like the camera makes it appear brighter!
7 hours ago, Opiedeegs said:
Looks great
Did you make this your self or is this a new product!
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,016 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
