On 6/25/2020 at 10:13 PM, Stand By said:
Have you contacted White's or anybody to see if it could be programmed?
On 6/25/2020 at 8:51 AM, Zelas said:
I Have swapped out my Steering wheel with a Leather wheel which has the Buttons on the right. I also have swapped the Speedometer with a High Country one. It does not work . The Cruse control buttons work however, I have to reinstall my old speedometer because I am not able to toggle thru the menus. Its a bummer because it makes a huge difference in the interior.
I think you also have to swap the 7” monitor functions out for the 8” display model. That also carries all the information for this switch to happen. I have tried this but I’ve wanted too so bad.
  • 3 months later...
Did anyone find a way to add the buttons on the right?  Just got my 2021 2500HD Base and it doesnt have the volume on the right either.  The blank is there.  Can it be added?
After researching the addition of radio controls on the steering wheel, I've concluded it can't be done without a huge hassle and expense.  As an alternative, I swapped in the leather steering wheel and used the blank on the right side of the stock wheel that came on my 2020 Silverado Custom.  I have Katzkin leather seats so I wanted a leather wheel to match so at least I have a nice steering wheel instead of the cheezy plastic stock version that came on on the Custom trucks.  The cruise control buttons on the new wheel work fine.
Edited by Mac-427
  • 4 months later...
Someone on YouTube added the steering wheel controls on a 2021 Silverado custom.  And harness dr has the line bus harness to add steering wheel controls. But I believe you have to upgrade the cluster as well and swap steering wheel.
I was able to work with the Harness Dr on my 2021 Sierra 3500 base, to get this working. I added the programmed cluster from WAMS, a steering wheel with the menu controls on the right and audio controls on the back. We added 1 wire (now available on Harness Dr website), which required no splicing, pinned at the cluster and pinned at the clock spring harness and this gave my wheel full control. Well worth while upgrade.
Hey Vradcliffe, this is a  pretty big deal for lots of us on the Forum.  Any additional detail would be sincerely appreciated.
Hey Mac-427, I’ll try to add some detail so forgive the long post....
the first thing I would do is remover the upper steering column cover, to expose the clockspring harness (yellow connector). If you remove the harness, you can verify if there is any existing LIN bus connection (slot 9). If there is no connection, you should be able to run a wire directly from slot 9 at the clock spring along the existing harness to slot 20 at the cluster connector. I would really recommend going to the Harness Dr. website and purchasing the wire for $26. It will come with full instructions (many of the pics are from my upgrade, just saying that as verification it worked) and it is pinned perfectly to fit in the slots.
Just as an FYI, I DID NOT replace the clock spring, as I’ve seen many people believe that may be necessary for this upgrade.
This upgrade has had at least 2 additional successful attempts that I’m aware of, to this point.
Thanks Vradcliffe.  I'm following this issue closely because I have the steering wheel controls that came with my replacement leather wheel so I'm at least part of the way there.
@Vradcliffe,
Thanks again for your involvement in this.  Your patience and dedication to see this to fruition is greatly appreciated.
Foe those looking into this, the harness can be purchased here.
https://harnessdr.com/product/2019-2021-silverado-sierra-steering-wheel-lin-bus-harness/
A few things to note:
A new compatible cluster swap is needed.  The new cluster needs to be custom programmed by WAMS - 2019+ (T1) Denali / High Country Cluster Upgrade Kit - White Automotive & Media Services - @GTPprix is the only company I use for this type of work.
Since a new cluster is needed, might as well upgrade to the nicer Denali or High Country Cluster.
A few customers have also reported that they gained radio controls (IOR) radios and have restored backlight illumination on the left side.
Keep in mind, that this is still a fairly new retrofit and release - so individual results may vary.
Thanks!
On 6/9/2021 at 12:43 PM, Vradcliffe said:
Here are the before and after photos....
I apologize, the before photo is the dealer stock photo, I didn’t take one prior to the install...
That does make for a great look. Would happen to have the website where you ordered the parts?
Thanks!
I completed this and everything works except the heated wheel. Ordered a high country cluster from whites, wire from harness dr and a wheel from the dealer. Cost me about 1k to complete. Yes that's alot but its really nice..!! Since it's a custom the stereo bezel didn't match, I ordered the silver one to match.
Edited by Flatblack83
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
    • That’s what I’m wondering is if the stock backspacing of the factory wheels will clear new upper control arms and such
