Well thats a new one. With the way those lines are running above the slider, maybe an issue with the defroster?
Either way please let us know what the dealer says. With the water leak issues and now this, not very encouraging with these rear glass issues
did you park on the sunny side of a mirrored glass building?
57 minutes ago, ILSilverado said:
Wow that’s strange.
I agree maybe superman missed his target??
Seriously though what in the heck could cause that, it goes from the bottom of the third brake light and continues past the slider section of glass and to the bottom frame portion.
Does everything still work? [Brake Lite, Window Defrost, Power Slider, Rear View Camera]
1 hour ago, econometrics said:
What the...
These T1 sliding rear windows are cursed.
That doesn’t look like a T1 slider though...
Not a T1 Silverado or GMC there's no rear cab spoiler. I also like to know why the lines are angled to the left and other picture there angled to the right.
Edited by Silverado4x4
Pictures are 2 different trucks having the same issues... This definitely is very strange!!!! What is going to happen next on these trucks!!!!!?..
Edited by scotman623
Exactly what it looks like to me. Intense reflection of a shiny surface focused heat. I've seen vinyl siding on homes similarly melted by the the Sun reflecting off window glass.
On 2/16/2020 at 3:49 PM, econometrics said:
What the...
If your T1`slider leaks it is cursed; if it doesn't leak it is blessed!
    DaleB
    DaleB
  • Who's Online   4 Members, 0 Anonymous, 1,318 Guests (See full list)
