I was loading the bed a few nights ago for the first time in the dark. I dropped the MPT and the lights were on. It was great.
Then the lights went out. I had to press the button in my fib again to regain lighting. Had to do this a few times to finish loading.
Is there a way way to get the lights to stay on longer than a few minutes with the tailgate down?
32 minutes ago, 19sierra53 said:
Ya, turn your cargo light switch on. Its on the left of your dash by the fog light switch
I saw that but assumed it was for the top cargo light.
23 minutes ago, 19sierra53 said:
Nope, box lights too and also the LED by the tailgate handle, or button i guess you would say now
It does seem a little silly to have to go in the truck to hit that light switch to turn them on long term.
Pressing the button in the cab more than once will change which lights are on:
- Initial Press:
- CHMSL/Cargo Bed Lights - On
- Cargo Mirror Lights - On
- Cargo Switch Indicator (if equipped) - On
- Next Press: (if with in 5 seconds of the previous button press):
- Cargo Mirror Lights - Off
- Next Press:
- CHMSL/Cargo Bed Lights - Off
- Cargo Switch Indicator (if equipped) - Off
The poor bed lighting was one of my first annoyances with the new trucks. There should be a switch inside the tailgate to turn them on.
I ultimately installed aftermarket LED strip lighting under each rail & wired it into the trailering plug wiring and added a switch by the grab handle.
  • Like 3
  • Thanks 1
Very nice solution.
My '17 F250 had a button in the bed that turned on the bed led's which was awesome.  It is still my favorite truck ever, just won't fit in my garage.
Nice, can you share how you ran the wiring and how you wired them to the trailer plug?
I removed the grab handle & behind it is a grommet. I fed the wires through the grommet & over to the back of the trailer plug located in the box. (I have an HD). From there, I removed the plug and disconnected the 12v hot lead & ground wire from the plug & made the connection to the LED light strip there. Once the connection was made, I put the plug back together and popped it back in place.
If you don’t have the box mounted plug, you can just run the wires further down to the standard trailer plug by the receiver.
  • Thanks 1
Thanks for the info.  Another project for me to work on.
On 2/23/2020 at 4:32 PM, wacnstac said:
Would have been sweet if there was a button on the FOB for this.
Yea or how about one in the bed?
  • Like 3
For some reason my LED bed lights that i installed flash every 5 or so seconds when my running lights are off (they are wired to be on when the running lights are on).
I wired them with a CURT 56584 wiring harness to avoid cutting or splicing any factory wiring harness and used the running light wire and ground to power the LED bed lights.
When I switch them on with the running lights on they also flash about 7 times then they finally power on normally.  Does anyone have an idea why they would flash?
Looks like the running light source has some monitor/power activity even when powered off.  Guess I will have to run power for the bed lights to the 7 way 12v constant and just remember to turn off the switch when not in use.  Either that or run them constant with a relay to the factory bed lights.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
    • I really did not measure what came out. I carefully followed directions to check level after i did the spill and fill and filter change. I used 10 quarts. 9 was not quite enough. My trans temp was about 175 when I checked it. Truck sitting in my driveway very close to level where I always check oil pretty much every time for consistency. My driveway is just ever so slightly downhill to run water to the street.
    • Sounds like maybe it's announcing Navigation turns or Alerts (it mutes the music) ? When it mutes again, turn up the volume quickly and see if maybe the navigation volume is really low?
