Same as 2011-2019.
  • (2) outer tie rod ends
  • (2) upper ball joints
  • (2) lower ball joints
  • (1) top of pitman arm at the center link side of the arm
  • (1) top of idler arm pivot bracket
  • (1) top of idler arm at the center link side of the arm
2 hours ago, newdude said:
Same as 2011-2019.
Doesn't the 2017 have rack and pinion? so it wouldn't have a pitman arm,...ect?
Sorry i was wrong. for some reason i was thinking of the 1500s. thanks @newdude
Edited by BlancoSilverado
A 2017 1/2 ton would have rack and pinion.  HD is recirculating ball/linkage steering.  OP was wondering on the 2020 HD trucks which are still recirculating ball/linkage steering, hence this post being in the HD section of the forum.
Edited by newdude
1 hour ago, Bigbucks10 said:
So i called the dealer, they dont even know.   Said they never greased one yet.
LOL! I was just thinking to myself if the dealer greased all of those at my first and only free oil change / maintenance visit...? But seeing as they couldn't even do a proper tire rotation, I'm doubting they touched the grease zerks. I will grease them when I do the next oil change myself.
I would suggest greasing them right away, as from what I've read other people report, they don't get greased at the factory, and at least some dealers don't grease them as part of PDI, so you probably are still on whatever minimal grease was in the joint by whoever made it.  The sooner it gets some real grease in it, the sooner it stops wearing out as fast...
As of 2019 model year, the PDI consists of installing accessories, installing air dams/center caps/etc, PDI testing the battery, check for leaks under hood, oil level, Optikleen in the washer tank and thats about it.  They no longer have the dealer do the test drive nor check fluids as fluids as the plants now verify fluid levels under the vehicle.
i just did all nine fittings.  you can get them all with a regular grease gun tool (not a 90degree one).  you must remove front skid plate and turn wheel both left and right.  Each fitting took min of 6 pumps grease.  I imagine they were not filled from factory.   Glad i got mine right away.  I would recommend at long hose (36 inches) and battery operated really helps if working by yourself.
The owner's manual says to lubricate the 2500/3500 steering components at least every oil change.
This is the multi-point inspection check list from the dealer's website that did my 1st service maintenance visit. I didn't get a copy of this form so I just called and asked if they greased the steering components. The service rep said they don't print out those forms anymore, and haven't for several years now. And they don't usually write down if they greased the steering components, but they usually do grease them and I should be fine.
Well I guess I will double check.
I would suggest crawling under the truck and checking.  It certainly wouldn't surprise me if you look and find out the dealer hasn't been lubing anything as part of an oil change or vehicle inspection.
So being a pretty handy guy, but not very knowledgeable about vehicle parts and components - are all of these areas that require grease easy to find?  I'm getting a little lost in the jargon.
You might try watching this video (not my video), he seems to show where the joints are.  Don't do what he did and wait until the joints are creaking before greasing them...
Thanks, I will take a look.
After hearing some of these stories, I am definitely going to start taking a more active approach in the maintenance of the vehicle.  I take it in for all the scheduled checks, etc. but double checking never hurts.
From what other's have said about dealer service departments (both for the dept as a whole, and individual mechanics), it's hit or miss whether you get everything done right or not.  Some just swap the oil & filter (and sometimes even botch that), and some will also lube everything, check and top off if necessary all the other fluids, rotate tires, etc...
I believe the phrase you want to keep in mind for this would be "Trust, but verify"
    • I am experiecing the same issue, I have gone in the setting and disabled rain sensing function but I am still experiencing this. Whe i use my turn signal they will redomly turn on. Sometime they stay on and others times we swipe 2 or 3 times and stop. Its super anoying, escpecially after a fresh wash. Anyone have any advice? . rain-sensing function, but I am still experiencing this issue Sometimes they stay on, and other times we swipe 2 or 3 times and stop.It's super annoying, especially after a fresh wash.When I use my turn signal, they will randomly turn on. I am experiencing the same issue. I have gone into the settings and disabled the rain sensing function, but I am still experiencing this.
    • If we actually used any significant amount of that source in the USA then I'd agree but we don't. We've had that discussion before. We drill and pump more than we use. Thing is, we sell. We export. Gas and Crude. It's more profitable so any shortage here is self inflicted and LEGAL.    I worked a gas plant that has multiple fuel sources available and I worked in the furnace and boiler plant in that facility. I'd had days we swapped fuel types four times in a twelve hour shift which isn't done on supply but on margin. Two of the fuel sources are internally generated. Tail gas and DAK, both of which are sold as well a consumed. We always had more than we needed to run the process but we chose the fuel that produced the best margin not bought at the cheapest price always. A good bit of math to that and back in the time that was done on a slide rule.     I worked the Shale Oil Semiworks of Chevron Research and CONOCO Research in Salt Lake City. That process never went into production although it was very successful. Why? Did we lack oil bearing shale? Nope. Price of crude never made the margins work. That was in the late 70's early 80's. Remember history? What was happening then was a reaction to that situation. It didn't drive it. If so then it's easy. This isn't a supply and demand thing. This is a profit and margin thing and AI rules that now.    In no refining situation that I was ever in would a bomb hitting a well anywhere in the world 'instantly' interrupt or even distress the supply. Most plants have more than a months worth of crude in the tank field and more in pumping stations. That yo-yo could play out over days, weeks and maybe months and have zero impact on plant operations. How many times has this been off and on in the last few months? These people and not stupid. These plants measure down time in hundreds of thousands of dollars per day. They are not sucking fumes or waiting on the next truckload with baited breath. Besides, as I noted, they are for the most part 'vertically integrated'. They own it from the dirt is sits in to the delivery rack and sometimes to the pump. It has a HUGE shock absorber built in. When production suffers, refining wins and when refining is winning exploration is killing. The rest of that crap in the news is a 'news cycle'. Government dipping in to reserves? Oil is stealing their milk money. There's a reason Chevron abandon Venezuela infrastructure and it had nothing to do with security of US citizens. Nationals run those plants. it has to do with MARGINS disappearing to corruption. They are in no hurry to return. Is there supply there? Oh yea. More than enough to offset what is bought in the middle east. Just isn't ???? Profitable.    We have supply. There are places in Illinois you can drive a pipe into the ground and run your homes natural gas furnace on it.    A refinery fire will gum up the supply works but not a localized war where the market is using a limited supply from. Now Europe, that's something other....
    • $4.00 a gallon here now.   Diesel nearly $5.00 again.
    • If we're talking futures, yes, it's speculation.   The spot price of a delivered barrel is elevated now compared to before the conflict. And that is related more to current supply/demand.
    • SPECULATION on the wars effect raised prices. AI is maximizing the profit. Refining is vertically integrated.
