Same as 2011-2019.
  • (2) outer tie rod ends
  • (2) upper ball joints
  • (2) lower ball joints
  • (1) top of pitman arm at the center link side of the arm
  • (1) top of idler arm pivot bracket
  • (1) top of idler arm at the center link side of the arm
  • Thanks 1
2 hours ago, newdude said:
Same as 2011-2019.
Doesn't the 2017 have rack and pinion? so it wouldn't have a pitman arm,...ect?
Sorry i was wrong. for some reason i was thinking of the 1500s. thanks @newdude
Edited by BlancoSilverado
A 2017 1/2 ton would have rack and pinion.  HD is recirculating ball/linkage steering.  OP was wondering on the 2020 HD trucks which are still recirculating ball/linkage steering, hence this post being in the HD section of the forum.
Edited by newdude
1 hour ago, Bigbucks10 said:
So i called the dealer, they dont even know.   Said they never greased one yet.
LOL! I was just thinking to myself if the dealer greased all of those at my first and only free oil change / maintenance visit...? But seeing as they couldn't even do a proper tire rotation, I'm doubting they touched the grease zerks. I will grease them when I do the next oil change myself.
I would suggest greasing them right away, as from what I've read other people report, they don't get greased at the factory, and at least some dealers don't grease them as part of PDI, so you probably are still on whatever minimal grease was in the joint by whoever made it.  The sooner it gets some real grease in it, the sooner it stops wearing out as fast...
As of 2019 model year, the PDI consists of installing accessories, installing air dams/center caps/etc, PDI testing the battery, check for leaks under hood, oil level, Optikleen in the washer tank and thats about it.  They no longer have the dealer do the test drive nor check fluids as fluids as the plants now verify fluid levels under the vehicle.
i just did all nine fittings.  you can get them all with a regular grease gun tool (not a 90degree one).  you must remove front skid plate and turn wheel both left and right.  Each fitting took min of 6 pumps grease.  I imagine they were not filled from factory.   Glad i got mine right away.  I would recommend at long hose (36 inches) and battery operated really helps if working by yourself.
The owner's manual says to lubricate the 2500/3500 steering components at least every oil change.
This is the multi-point inspection check list from the dealer's website that did my 1st service maintenance visit. I didn't get a copy of this form so I just called and asked if they greased the steering components. The service rep said they don't print out those forms anymore, and haven't for several years now. And they don't usually write down if they greased the steering components, but they usually do grease them and I should be fine.
Well I guess I will double check.
I would suggest crawling under the truck and checking.  It certainly wouldn't surprise me if you look and find out the dealer hasn't been lubing anything as part of an oil change or vehicle inspection.
So being a pretty handy guy, but not very knowledgeable about vehicle parts and components - are all of these areas that require grease easy to find?  I'm getting a little lost in the jargon.
You might try watching this video (not my video), he seems to show where the joints are.  Don't do what he did and wait until the joints are creaking before greasing them...
Thanks, I will take a look.
After hearing some of these stories, I am definitely going to start taking a more active approach in the maintenance of the vehicle.  I take it in for all the scheduled checks, etc. but double checking never hurts.
From what other's have said about dealer service departments (both for the dept as a whole, and individual mechanics), it's hit or miss whether you get everything done right or not.  Some just swap the oil & filter (and sometimes even botch that), and some will also lube everything, check and top off if necessary all the other fluids, rotate tires, etc...
I believe the phrase you want to keep in mind for this would be "Trust, but verify"
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
