I'm just wondring, can I get a setup so I can install some fuses or a fuse on the battery of my LBZ (06' 2500HD) similar to the fuse for the plow with this kit? Im installing a winch on the 06 and some other things and this style set up would be clean ...
On 10/30/2020 at 9:56 AM, Gecko50 said:
Requester,
The Service Parts 9L7 retrofit kits are NOW available.  Below is the kit P/Ns based on the vehicle’s interior color and whether it has push button (BTM) or keyed ignition start. The table below then provides the list of P/Ns that are included in the kit for your vehicle application. NOTE: dealer price for these kits is $126.92, if more pricing information is required dealers are recommended to contact the pricing center customer assistance and request pricing.
  • 84942071 for use with Jet Black interior and keyed ignition (-BTM)
  • 84942072 for use with Very Dark Atmosphere Interior and keyed ignition (-BTM)
  • 84942073 for use with Jet Black interior and with push button ignition (+BTM)
  • 84942074 for use with Very Dark Atmosphere interior and with push button ignition (+BTM)
Kit #
84942071
84942072
84942073
84942074
Knee Bolster
84487351
84487352
84487354
84487355
Switch Bank
84688687
84688686
84688687
84688686
Fuse Kit
84669070
84669070
84669070
84669070
Fasteners
11589015 (2)
11589015 (2)
11589015 (2)
11589015 (2)
Aux Fuse Block
84645397
84645397
84645397
84645397
Under Hood Wiring harness
84794790
84794790
84794790
84794790
Retainers
11589290
11589290
11589290
11589290
The dark coco color interior is called "Very Dark Atmosphere" Now look carefully at the part numbers as it depends on how your truck is outfitted with OR without a key type switch. I did my own taking my time and I can say you will have to disassemble the entire (or most of it) the center console. Do a search and a good article is on Diesel forums. I had to redo the entire writeup in MS Office as the photos were messed up. I again took my time. I utilized my own means and methods.
Good Luck
Chuck
so what style switches are these  momentary or latch or both
So what type of switches doe this kit have. is there momentary and latching. or ar they all latching switches  i need momentary for air horn. two im thinkinmg about retrofitting the button panel to the upper roof console using the sunglasses compartment.
Not for sure what you mean, but these button click in and stay in with a light illuminated when pressed. You have to press them again to disengage.
Hello everyone. im new here. but i have been searching and browsing for answers. does anybody here know why this kit will not work on a 2017 gmc 2500hd. the only thing i can think of is cause of the gray plug that plugs into the factory harness. They probably didnt start putting that factory plug in till 2019 and up. if so  i can hard wire it in. i just need to know what wire is what  thank you
On 10/11/2021 at 5:23 PM, Cali Crusin said:
Man you all are so lucky that the newer trucks have this factory (custom) option.. I have a 2017 GMC Sierra 1500 SLT that I want to add switches for, but I don't think this will work for me. Am I correct in that?IMG_4690.HEIC
Hey Cali Crusin, were you able to figure it out on this kit to install it on your 2017. im in the same boat man. im sure someone has a write up wiring it up with the plug. (hardwire )
You could probably get most of it working if you really wanted to. Like you said, the gray plug would be the most difficult because it is only on the newer trucks. That plug is the BCM controls, so I don't know that it is as easy as just tapping wires, but it could just be for backlighting, ignition position sensing, etc.
Good luck if you decide to tackle it. It's difficult enough on trucks that were designed for the kit. Personally, I'd just find a different aftermarket kit and find a clean way to wire that up.
  • 5 months later...
This is really a great discussion on installing the upfitter switches.  I just got my 2022 3500 that was ordered with the kit as an option.  Much to my surprise I found the switch cluster was already installed in the knee bolster and now just the wiring remains.  After actually reading the UI Bulletin I see that the 2500/3500 have the knee bolster with the switch cluster installed during the build.
So the relay/fuse box and power cable remain to be installed.  The cables from the fuse box can be easily connected to the power cable and the 14-pin connector Aux Fuse Block.  But, I can't see the connector on the back of the switch cluster for the 16-pin switch bank connector.  How do I install that connector?  I find it hard to believe, but not impossible, that the switch cluster would be installed in the knee bolster at the factory, but then would have to be removed to install that one connector.  Can the switch cluster be pulled/pushed out to expose the connector or would that damage it?
Thanks for any help.
I'm  not 100% sure on what your exactly talking about.  BUT if you mean the connector that plugs in to the back of the switch in the knee bolster.  It's included in some bubble wrap and you install the provided wire to that connector after running through the firewall then plug er' in n go.  I installed this with ease in no time at all and I think of myself as electrically illiterate.  You don't have to remove rhe switch panel deal to install anything. Although I'm sure it more than likely is possible.
Do you remember if there was a socket on the back of the switch cluster that took one of the cables from the fuse box?
Go all the way back to the first page of this thread and look at the pictures and instructions for opening up the dash. Once everything is unscrewed you can just pull the panel that holds the switches forwards to access the plug from the fuse box.
On 3/26/2020 at 7:17 PM, blamkin86 said:
OK we are rounding the last corner and heading for the final stretch of this phase.
First, grab the fusebox, and hold it near where we'll be installing it:
First, the black plug you just put on the red wire from the first steps, plug that into the fusebox. I don't have a picture of this, but there's only one place it can go.
Next, take the grey plug from the fusebox harness, and plug it into the grey plug where you removed the blank/empty end:
Next, run the last unused black connector from the fusebox to the actual upfitter switches on the kickpanel:
At this point, you're switches are wired into the harness in your truck.
One last step here - and this is where you may deviate from what I do. Because I knew I didn't want to take all this off again, and because I didn't have specific screws that would work AND because the screws that I took off the truck did work, I reused them. You may want to do something different.
In any case, match up the two screw holes in the fuse block with two empty holes on the support beam right behind the kickpanel, directly under the steering wheel. They're kind of hard to see, but I did manage to get a picture of me tightening down the screws.
So, once it's tightened down, double check that you've
1) plugged the grey plug from the harness to the grey plug where you removed the blank connector
2) plugged the black plug from the harness, through the supports, out the dash, and into the back of the upfitter switches
3) plugged the new black plug that you added the red wire into the fuse box.
It maybe is also a good idea to see where you left the four loose (electrical tape) wires. Whatever you wire to these switches is going to have to come all the way back to one of these four wires. (Sorry, this is one case where Ford got it better- their wires are all outside under the hood. Sorry, I don't like saying that either, but theirs is better.)
@mobilelists you can see in this post the plug that was used for the switches.
So it appears that the kick panel still has to be removed, or at least partially removed.  I will have to see if I can borrow a  scope to look up there and try to connect without doing that when I have some time.  The metal support brackets are blocking my field of view.
You don't have to fully remove it to access the back of the switch. I didn't fully remove mine, I just bent the plastic enough to install the fuse box and connect the switch. Pulling the panel back really isn't hard at all, removing it entirely would be difficult.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
    • Oil and filter threads are always a good time.  Especially when the BITOG discussion forums are cited as a definitive, technical source.    Countless single-data-point examples of why something is the best ever, or will destroy your engine... "they changed the shade of blue on the filter can, use at your own risk!"... "I've heard they changed the design to only have 64 pleats, total junk!"... "They're hidin' the NOACK data from us!  I wouldn't use that stuff in a cement kiln!".... "There was a guy who cut open Filter X (with a sawzall) and the anti-drainback valve was orange!  It used to be black!  Chinese junk!"   Good stuff.
