1 hour ago, DirtyAndy said:
Your complaint is one reason I jumped from a Sierra Elevation to an AT4 during the test drive. I’m also tall at 6’6” and usually the bench seat trucks were more comfy for me. Not this time around.
Floor center console comes nowhere near my legs.
You can get the centre console in an Elevation...
Didn’t know that. I’m more than happy that I jumped to an AT4 though. Rides and drives way better.
13 hours ago, Cpl_Punishment said:
Seems like something that might have come up during the test drive...
it only happens on long drives. It wouldn't of came up on my test drive.
Really? It came up on mine and it was 10 minutes at most. Lol.
Mine was 5 minutes at most, lol.  I should have done my due diligence and drove for at least 20 minutes.
One of the reasons my LT is getting the full console,I have the console but need a few parts for it that GM is shipping very slowly.
  • 3 years later...
On 3/30/2020 at 8:01 PM, Gangly said:
You'd be surprised how many times I've told myself that.  Maybe a test drive longer than 5 minutes would have been beneficial?  Probably.
Hi there, did you come up with a solution to the seatbelt plastic digging in the leg? I literally have the same exact problem. Bought truck yesterday and leg is killing me. Didn’t notice during test drive.
I placed a towel underneath the console which raised it up high enough to where it doesn't interfere with my leg.
I put the full center console into to my Custom but I had a helluva finding one. I have seen some on ebay for $1500.00! What a ripoff.
  • 1 year later...
I will fight the GM engineer that made this…. Love the truck except for that.
thinking about taking the jump seat apart, removing the leg sticking S.O.B and printing something better.
C’mon GM, that one suuuuucks.
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
