On 5/10/2025 at 3:32 PM, GETGONE said:
I've run mine to 112 countless times with zero issues. 31K miles and still going strong. Took it to a test and tune and ran about a dozen passes trying various launches, no issues. Best of 14.2 in the 1/4.
Nice time!  If memory serves, that 112 mph problem applied to K2 1500s.  I recently learned that my kids have been exceeding 112 with their GMT900s with 6.2s too!
Driveshaft seems to get a lot of the press, but tire speed rating should be looked at too.
(yes, I realize that exceeding speed rating isn't likely to cause immediate failure...)
Do they know about tire speed ratings?
Speed (and load) rating will also be on the tire.
Factory tires on my '21 were speed rating S.
S
An S speed rating indicates the tire has been approved for speeds up to 112 mph (180 km/h) under optimal conditions. Everyday passenger vehicle tires can be S speed rated, but S tires often prioritize specific performance or function. Many all-terrain LT tires are becoming available in an S rating as that’s the OE spec for many of these vehicles like the Ford Raptor.
This is was on a set of Duratracs I used to have.
Load load rating 109, speed rating S
Current '23 has  275/60R20 115S
So again, speed rating S
My current winter tires are speed rating R.
Speed rating R allows for speeds up to 106 mph (170 km/h) under optimal conditions. Like Q, R tires generally prioritize a particular function or unique performance over maximum speed capability. R speed tires are rare but can be found on some heavy-duty light truck (LT) tires, as well as studdable and studless winter tires.
Edited by redwngr
Speed Rating Miles/Hour KM/Hour Typical Application(s)
L 75 120 Trailer tires
M 81 130 Spare tires
N 87 140 Spare tires
P 93 150
Q 99 160 Select winter tires
R 106 170 Passenger and light truck tires
S 112 180 Passenger and light truck tires
T 118 190 Passenger and light truck tires
U 124 200
H 130 210 Passenger sedans, coupes, SUV and CUV’s tires
V 149 240 Performance sedans, coupes, and sports cars tires
W 168 270 Performance sedans, coupes, SUV and CUV’s tires
Y 186 300 Exotic sports cars tires
Z 149+ 240+ High-Performance vehicle tires
Trail Bosses with the 18" tires are electronically limited to 98mph due to tire rating. The 20" wheel option bumps the limiter up to 112mph because of the S speed rated tires.
LOL. Busted.
My 2000, GMT800, that I still have, has a 128 limit. I have seen 4000 rpm`s in overdrive with 16 inch wheels and 3.73 gears. Poor 100 mph speedo.
16 hours ago, PunchT37 said:
LOL. Busted.
I'm curious what the tire loading label on the doorpost lists as the speed rating?
Edited by redwngr
S. But, this truck has a whole new computer.😉
Thanks.
So if they were installing S rated tires on (at least some) 2020's the original limiter was likely lower/
4 hours ago, redwngr said:
Thanks.
Thanks.
Factory limiter on that 2000 truck was 96 mph.
  • 5 months later...
I have yet to top mine out since I had it unlocked and then tuned it (High Country 6.2 10 spd), but my tires will limit me as I have a brain. But damn the ecm and tcm tune feels great. If anybody is on the fence, just do it. I'm still tweaking some of the shift times to get rid of the sluggish shifts on lower power shifts. mid power shifts are .200 seconds and full power are .100 seconds, tires chirp with only a small boost in pressure and reducing shift times.
Edited by Silveradgo
Who tuned it and how much did it cost you?
Any mods beside the tune?
I tuned it. Only have a K&N Blackhawk intake on it for the sound. Longtubes will be the next go-fast mod.
Edit: I'll have to get a video of the induction noise during the 1-2 shift at like 4.5k 🤤
How did you tune it since you have to send in the ECM last I knew to get it unlocked to be able to tune it.
See my earlier post
4 hours ago, Silveradgo said:
See my earlier post
You have 3 posts. You just said you had it unlocked and you tuned it. That tells me NOTHING. WHO unlocked it? WHAT are you using to tune it? New member sounds like a troll.
    250.6k
    Aries68
    Aries68
  • Who's Online   6 Members, 0 Anonymous, 340 Guests (See full list)
