I received an Email from Range Technology today stating that the disabler for D.F.M. vehicles is now available. I am aware that several members of this site were beta testers. Can any of the folks who were testing them give any feedback on how well the units perform? Any issues that arose? Did the test units have to be sent back for updates?  Overall satisfaction?
I beta tested and I love it. I will continue to use it. I recommend the buy if you want to have it in V8 and stop auto/stop start. I only take mine out when going to the dealer for service and then plug it right back in.
I had no real issues to speak of though you will feel a more rough transmission shift. At least i did with my 8 sp trans. No CEL or any other issues. I never had to send my unit back for any updates. Worked from day 1 of beta testing the whole way through. I did notice a slight drop in MPG by about 2 mpg but that is because I was having fun in V8. When on the highway I was only about .2-.5 mpg less on normal highway trips. So really not that bad.
Can you please tell me why you would use this in the first place? I understand turning off the auto start stop but why disable the DFM and cause rough shifting and higher gas use? DFM is seemless. Do you actually feel it in some way? Trying to figure it out if I am missing something?
There are plenty of threads on this but for me I paid for a V8 and I want a V8. Besides the fact that AFM was plagued with lifter failures and oil consumption issues. The people who had their engine in V8 all the time has much less of this happen. For me the little bit of fuel savings won’t even out $$$ wise for repair costs. Granted it’s under warranty for repairs. But like I said before I paid for a V8 and want a V8 not some other number of cylinders.
  • Thanks 1
While they released a DFM disable, it doesn't work on anything with the 10 speed trans yet.
Jay
Ok thanks for the explanation. I guess I knew that it had DFM when I purchased it so I knew it was a V8 that has advanced cylinder fuel management so it doesn’t bother me and it equals better fuel mileage and it’s warranted.
I think to try and put some aftermarket device on my 6.2 that has such complex control logic and turn off something that was designed in deeply into the way the whole systems is intended to function may result in bigger problems.
I appreciate the explanation. It’s not for me.
thanks again.
I had one in my old 2012 5.3  Sierra SLT Z71. Only "issue" I ran into with it was run the vehicle without it for a day or two PRIOR to having an emission test if your state requires one. My fist time I removed it when I got to the test station, which did not allow the computer to "set" to its  required test parameters. Left it out for a couple days and returned to the test station without issue.
I still have the old Range box. I wonder if it could be updated to work on my 2019 DFM truck?
  • 3 months later...
Jay
I inquired about this issue to the Range tech dept. Here is their answer: We unfortunately do not officially support the 10 speed vehicles yet. The units that we currently have will generally work for the 10 speed vehicles, but there are some minor kinks that still need to be worked out with them before we officially release anything.
this tells me that it may or may not work with the 2019 10 speed new body style
  • Thanks 1
So I went ahead and picked up one from Summit Racing near me and plugged it in. Started and drove about 30 miles and so far it's working like it should. V8 sound all the time. With the Borla catback exhaust it now sounds like a truck all the time. No engine stop at redlights. So far so good. Will drive it some more and report back in a few days. I did keep the box and receipts just in case.
well, almost 2 weeks have gone by and I have driven right at 500 miles and many start stops along the way. So far the AFM/DFM unit has worked to perfection. NO codes have been thrown and  the automatic start stop is no longer a PITA. As for fuel mileage I can't tell since most of the driving has been in town. I still average around 15 mpg in town driving.  2019 High Country 6.2l 4x4 crew
Thanks for the real-world feedback. I usually get 15-16mpg in town with my 5.3L RST, so it seems like the lack of DFM hasn't really hurt you too much so far. I'm sure it really only puts a dent in MPG on longer, flat highway runs.
thanks again.
Nearly everyone that runs one does so to avoid oil consumption issues that will lead to piston replacement and/or lifter failure in the future. Jury still out on the 19-20 models I would say but anyone that went through it with the 2007+ models runs AFM/DFM delete.
Someone correct me if I’m wrong, but can anyone with the 10speed/6.2L get the same result by pressing the auto start/stop button and driving in L9... the only difference being losing 10th gear?
My guess is yes.This would stop start/stop and stop v4.
Yes.
  • Thanks 1
    • Thanks for response. Leak was right under drivers seat or thereabout.   Had checked by other mechanics and have read other information.   The solution can be a tad complicated and replacing multiple parts And with some.  The issue was still the same.   The brakes do work.   Just that the pedal is softer and goes further down.  But the brakes do work.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
