Good morning all, I'm looking to remove the halogen headlights and install LED lights. Does anyone know if the 2015 Silverado 1500 is a CANBUS system? If so what LED lights and defeaters did you use? Thanks
I forgot to put that in my initial post. I have reflector headlights.
Don't put LEDs in if you're not willing to pay the premium for ones that mimic the halogen, such as diode dynamics SL1
If it was me I would stay away from any LED that has a fan.
I like these. Best warranty, nice price and no fan.
I have been debating getting these LEsS for all my truck lights. High , low and fog.
Through emails with this company they say they design the LEDs for each application.
https://www.headlightexperts.com/carfinder/?find=2015-chevrolet-silverado-535429
Now I'm leaning toward and LED light bar. Great light output, less money.
Horrible advise. Fans are how they cool. You listed overpriced garbage that will blind other drivers.
7 minutes ago, diyer2 said:
Another know it all.
Read the reviews on yours then mine. Look at the product pictures. Look at the company reputation. Who wouldn't spend $50 more and get the best product for this application? The ones I listed are actually showing his vehicle unlike the generic ****** pic others use.
OK, you have your opinion and I have mine.
Agree?
Your brand has no high beam LED.
3 year warranty.
Reviews are opinions and I like to evaluate things myself so reviews don't mean a lot to me.
I didn't recommend the brand I like to start an argument or a debate.
How do you know my brand is garbage and will blind other drivers?
I don't mind you posting your opinion but your not an expert.
And by the way I don't hold experts in high regard either. Expert or not it's an opinion.
Done.
I certainly appreciate the input. Does any one know if I will need the warning cancellers? My last car had a CANBUS system where the computer monitored the whole car.
You do not
I would not buy the junk from headlight experts posted above. I would buy the diode dynamics bulbs.
Putting led's into projector housings is generally a bad idea because most LEDs are not designed  for that type of housing, they're often cheap sales gimmicky products that won't give you a good result. It doesn't matter how bright the light is if you are spraying it everywhere but the road.
And Led's are okay, but I prefer a good HID retrofit to led light, maybe in the future LED's will catch up
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
