4 hours ago, MaverickZ71 said:
It's all about buying a 'license' to be able to advertise your brand as being Top Tier or Dexos or Dexcool 'certified'.
You'd think it would be as simple as submitting a sample to an independent lab to get tested to prove the quality of your product.  And it should be.  But there's a whole lot more to it than that.
It's just another power and $ grab by certain vehicle manufacturers.  Essentially they're saying "You pay us whatever we think it's worth for you to be able to buy a license from our syndicate to get 'certified' and in return we'll imply to the purchasers of our vehicles, both in the owner manuals, maintenance schedules, and various advertising, that they must use your product or their warranties will be voided."
Other 'non-licensed' brands may be just as good or better, they just chose not to play the old extortion game.  For example, Ford used to recommend BP fuel exclusively, but not anymore.  And at that time, our Ford ran better on Phillips66 gas than it did on BP.  Go figure.  There was talk on here and over on BITOG on how Valvoline (and others) refused to get Dexos-'certified' when GM first came out with the standard, even though their oil met the 'specs', but most of them have since drunk the GM corporate Kool-Aid and gotten themselves 'licensed'.
Back to the OP:  So don't necessarily worry about "Top Tier" fuel.  Buy at a station you trust (not necessarily the cheapest fuel in town) that does a volume business.  If running some additive (some on here running Lucas and AMSoil additives) sometimes makes you feel better, especially after a suspect tank of fuel, go for it.  Enjoy your truck!
Interesting info. Thanks. Is the process for gasoline the same? The reason I ask is because I think there are a lot more companies on the list of top tier gasoline stations (if I recall correctly). So I'd be surprised that a company would pay for the gasoline certification but not the diesel one.
I noticed that top tier thing the other day at Costco. It’s the only place I’ve filled up (2nd tank) and this is my first diesel so I really haven’t gotten diesel anywhere else. And probably won’t for that matter.
Diesel prices are all over the place here. I live in a small town so the two local stations typically have higher prices than what I could get going into the city. Even with regular gas, the local stations are typically 40 cents higher. With diesel, I’ve seen as high as $3.47 locally. Costco actually had diesel for $1.93 which was cheaper than regular gas at $1.99.
Most people are unaware of how incredibly dirty diesel fuel is and the need to help it with additives. Diesel is cleaner in the USA than in Europe but their fuel has a higer cetane rating. Adding a cetane booster that also helps with the fuel lubricity and an injector cleaner is worthwhile though not needed for every tank of diesel burned. Lots of these additives are available and I go with the least expensive in a bottle the size that works with the 36 gallon fuel tank so I do not need to measure it out at the pumps. No reason to go with Amsoil for anything and the mediocre performance of Amsoil diesel motor oils makes me avoid all their products.
Diesel is going to cause more problems during the winter in areas where all you can buy is biodiesel. There is still a problem with algae buildup in diesel and an additive will keep this from happening and avoid a very expensive repair job.
A diesel fuel filter that removes 98.7% of the particles in a gallon of diesel fuel will allow 240,000 particle to pass through and hit the injectors at high speed. Also a 2-micron filter will allow particles up to 10 microns in size to pass through the filter media. And changing filters more often is actually detrimental as fuel filters, like air filters, are least effective when new and before any media loading has taken place.
Diesel engines take a great deal longer than gas engines to reach their optimum operating temperature and so avoiding short trips of less than 30 minutes duration is best avoided.
I have a bunch of optilube, so I added it to the 3.0. My fuel economy went down to 27 form 30. I ran 2 tanks without and back up to 30. Added again and back down. Don't have a clue why. Same brand fuel same type of driving.
Which formula were you using?
Interesting. I'd always heard the opposite in the past.
Same here since they use more in personal vehicles than we do.
I'm starting to notice a trend with the "facts" this Wintersun guy shares...
Looking at the SDS for AC Delco Diesel Fuel Conditioner you can see the ingredients.
Section 3. Ingredients
Solvent naphtha (petroleum), heavy aromatic 30% - 60%
2-ethylhexyl nitrate 15% - 30%
Ethylbenzene 0.99% - 4.99%
Xylene 0.99% - 4.99%
4-trimethylbenzene 0.99% - 4.99%
Naphthalene 0.99% - 4.99%
The only other fuel conditioner that matches the ingredients is PEAK Blue Agri-Clean Liquid Fuel Stabilizer Additive for Diesel Engines. However the Peak-Blue doesn't give any percentages on the SDS.  I have look at the SDS for all the diesel fuel additives from this list.
https://www.thedrive.com/reviews/27711/best-diesel-fuel-additives
  • 7 months later...
I have a couple of 5 gal. plastic gas cans that are full of diesel that I bought several months ago for my tractor, they're stored out of the weather but in a metal storage container that gets over 100 degrees in mid summer. Should I use this fuel in my Duramax if it looks OK?
Hell no. Risk damage and headaches over like $50 worth of fuel?? Not worth it.
If you choose to use the stored diesel fuel I would run the tank down, add the fuel from the cans,  then add fresh fuel at the pump.
I see no risk here, diesel fuel can be stored for technically decades and still be ran in vehicles. If anything just get one of those cheap paint screeners to pour the fuel through and call it a day.
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
    • It costs $5,250 for the Yukon Nightfall option (black wheels, emblems and illuminated black GMC grill badge). What a "deal".
    • I keep getting the above error message on my 25 Sierra.  If I reset the infotainment unit (via the phone hang up button) it will work again for a day or 2.   But I dont want to do have to reset  all the time. Works fine in my 2023 Corvette. On both vehicles I connect wirelessly.   I have a Google Pixel 10 Pro XL, phone is up to date.  Any Ideas.  See attached
