I’ve been seeing folks on other forums talking about UCA failure/breakage as a result of leveling kits- specifically the MotoFab 2.5” upper strut puck system. Has anyone got any experience on this?  I’m currently running the Zone 2” upper pucks up front and wondering if I need to go back to stock for the time being.
I have been seeing the same thing and my zone kit just came in the mail. I am looking at holding off for now and buying some upper control arms from Cognito and swapping everything out at the same time.
Everything I’ve seen though has been with a 2.5”. Have you seen anything from a 2” puck system?
  • 5 months later...
So if i'm understanding this... 2in your good.... any more your playing with fate?
Just talked to service department about this and he told me no issues doing and they will do my truck as soon as it comes in. Not sure of brand they are using and I know I could get it done cheaper somewhere else but I figured if they installed and approved then if something happens its on them
I'm in the process of changing struts and adding zone upper control arms. Mines a trail boss and I added 1.5" leveling block to offset the winch I have. (My balljoints are shot and a strut is blown after about 15k miles). Seems like the problem is is the ball joint binding up when the suspension unloads. Id just get the control arms and be done with it.
I have a 2.5" motofab on mine.  What UCA will work with 2.5" ?  I've seen for 3" and above but not sure if it can go on 2.5" even though its only half an inch.
Seems to be the consensus.
The factory control arms are engineered for both the 0" of lift on a regular 1500 and the 2" of lift on the Trail Boss. It's the same UCA on both trucks. Lifting a non-Trail Boss truck  2" is putting the UCA and ball joints at essentially the same operating angles/conditions as a stock Trail Boss. This is why the only GM designed, authorized and warrantied 2" lift for non-TB/AT4 trucks does not include, or require, new UCAs. The GM 2" lift kit is basically comprised of the different/additional parts from the Trail Boss/AT4.
My thoughts, I wouldn't change the UCAs on a non-Trail Boss with a lift up to 2" but I would change the UCAs with any additional lift on a Trail Boss or an AT4 (already at, or near, UCA limit).
JMHO
No expertise implied or expressed
Well said.
There are so many on Facebook with problems with those arms from everything besides stock. Most of it tho is with the bigger tire like 35s.  If you never seen how bad a blown upper ball joint or one ripped off the arm looks you might want to. If it was me it would be a piece of mind to just do ucas.
got a link to pics...thanks
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 290 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
