Being new to the forum world I hope I'm doing this right.
I recently purchased a 2015 GMC 2500 HD used with a newly installed CM flatbed.
80000 Primarily highway miles and very clean and well kept.
Purchased from a dealership so previous owner history is not available due to privacy laws.
Everything on this truck works like new except a few functions of the electric Mirrors.
 They are manual extend and manual fold and both upper panes adjust fine.
The problem is that the turn signals do not flash in the mirror "dots", the Amber clearance lights do not come on and the rear facing white lights do not come on with the box lights.
No way of knowing if the heated part works being it's summer.
Trying to search the owners manual for fuse information was a bit of a challenge so I tested all fuses for power on both sides and all that have any power have power on both sides in all 3 panels.
I thinking that one of the relays or circuit breakers must have failed and are not labeled for function that I can access.
 Fuse labeled htd mir has no power on either side.
 Any help would be greatly appreciated!
 GB
the mirrors were probably not the original mirrors. being a 2015 it might be missing the wiring circuits for the lights, the best thing to do is to get a hold of Phil at harnessdoctor.com
I agree with the above post. Could be aftermarket swapped on and not wired or factory upgrades swapped on and not wired. You'll have to check the harness to see if it's pinned for those functions.
Build codes claim it had tow mirrors
It would be really odd for both mirrors to lose those functions. What module actually controls them? I would think there would be another relay for the signals in the mirrors unless it just runs off the turn signal relay? Have you tried checking for power/ground with the directional on to see if it cuts in and out?
I would really like to find someone who knows which relay powers these functions but it seems they are scarce.
Operators manual is no help as is the local dealer.
He just wants me to schedule an appointment for it.
Seem as though someone one here would know but figuring out how to reach them is my biggest issue.
You were correct!
The mirrors from the factory wee code DL8 and ones currently on it are DPN.
Door harnesses or adaptors required!
when i did my mirrors on my 2014 i made my own harnesses and it took me 9 hours start to finish. you can get all the info from this post
if i was to do it again i would get the harnesses from pgamboa
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
