I just kit 45k and want to do a trans fluid / filter change. I checked my dip stick and the first wipe was black. Checked it after and its light pink. Firet time I really checked it since owning at 10k miles. I have the diablo tune. I think i want to turn off torque management.. Not sure tho. Service manual only says to change it at 45k for severe use. I tow my 900lb atv once every few weeks. And I have 34" tires. Otherwise thats all.
Sent from my SM-G950U using Tapatalk
Fluid changes are cheap insurance IMO.
Owners manual also shows you how to check your oil. Do I need to elaborate?
Did you check for any tsbs? Sounds eerily similar to the 8spds problem's until they came out with the new trans oil.
I would consider the larger tire to be taxing on the trans and would have the fluid filter changed.  Maybe some other guys can chime in also about whether switching the Torque management off will actually help.  In theory I would think yes but get some more opinions.
Being that these are a torque based computer, turning off torque management is not an option. The problem isn't torque mngt either because you can make the transmission do exactly what you want it to do without ever really touching it.
Adjusting shift points, shift time and torque converter settings are key to a good transmission tune.
Been a busy week for me. I didn't watch the video and I get on here when I can.  How often did you change out the transmission fluid?
10 hours ago, aanold said:
Torque converter chewed up my 6L80E.
https://youtu.be/pcSJN_E1KOw
2016 Silverado 1500 LT
Black
2.5 Level with Eibach Springs and Struts
Flowmaster 40 Series
Well, it wasn't the transmission that failed then, it was the converter!  6L80s are very reliable but were made less reliable when GM put the thermostat on them to help with emissions.  Get rid of it and change the fluid every 40K miles or less if towing a lot and they'll last a long time.  Average life in a GMT900 is about 170K miles and that is usually just the solenoids that need rebuilding which costs $100 plus fluids and you do it on your kitchen table.
Mine started acting up at 45,000 miles.
Did a pan drop and filter change, no help. Torque converter shudder. Sold it with 52,000 miles. Truck was babied from day one, mostly highway mileage, never towed, never hauled anything, bone stock tires and rims. Well maintained, made no difference.
And I wasn't the only one that I personally knew with the same problem.
Shoulda beat on it more lol. I like watching the grandma car pull out into traffic and it's the first time they really stepped on the throttle in forever. Massive clouds of black soot come out the tailpipe because of all the carbon build up.
Not saying that driving it harder would have saved it but I drive all my vehicles hard and have yet to suffer any major failure because of it.
  • 1 month later...
we all know what the problem is . but no one is saying' lol  .10 cent part cost everyone $4000 i call it GM's planned obsolecence
Edited by flyingfool
2 hours ago, flyingfool said:
we all know what the problem is . but no one is saying' lol  .10 cent part cost everyone $4000 i call it GM's planned obsolescence
So agree!  Horrible way to do business.
Since the rebuild I love the truck again but I notice that with the stock tune you can notice the torque management easing in to the next gear way too much.
It reminds me of when someone rides the clutch too much to try and smooth out the operation of a standard tranny.
you might need to have a tuner correct the timing tables for the engine vs TM
    nolankd
    nolankd
  • Who's Online   2 Members, 1 Anonymous, 438 Guests (See full list)
    • For a limited time, retail accounts receive a free fender cover (G2803) with their order of $750 or more when they use code FENDER926 at checkout. The promotion runs through Sept. 8, 2026. Own a business and want to apply for a retail account?  Apply here. https://www.amsoil.com/business-opportunities/sell-in-your-store/?zo=521390
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
