Hello all.
I have a 2017 2wd CC 5.3L auto, just this week hit 70k miles.
My problem is at a steady speed, I hear an on and off low roar coming from the engine area. It goes away if I let off the gas or apply more gas. The engine is also hesitating during this issue. I got on a highway and put it on cruise and it does the same thing. I can even see the RPM's go up and down.
15 hours ago, mrpj1972 said:
Hello all.
That's a good looking truck!
Any vibrations? TC could be going bad, the engine revs fluctuating (flares), usually are tied to the transmission.  Maybe a lifter failing? Any CEL's present?
Edited by JimCost2014
11 hours ago, M1ck3y said:
I would guess it's the throttle body. Dealership + warranty = fixed
Would that be something covered under warranty?
No vibrations, just the hesitating. Almost like something is binding. That's the other odd thing, no CEL's at all.
I would suggest this.
Freeway on cruise control to duplicate the problem. When it starts acting up down shift the transmission to the next lower gear.
See what happpens.
See what happpens.
I will try that later today and report back.
1 hour ago, It's Tim said:
Is the transmission temperature crazy hot?
I looked at that and saw a temp of 190. Is that out of normal?
Ok, stand down.
Definitely the trans.
Barely made it back picking up lunch.
Severe slipping.
Called tow company to take it to the local reputable trans shop.
I'll update the findings when I can.
Yeah it's the tcc/trans. What you were describing in your original post indicated something different. Best of luck
Don't you have warranty? The bill for that is going to be steep.
Edited by M1ck3y
70k on the odometer and I neglected to buy an extended warranty when I bought the truck a couple months ago. ?
Good luck mrpj. Is your trans the 6 speed or 8 speed? I just had to replace a 6 speed on a 2016 Silverado with 77,000 miles. No warranty so it was a $4800 out of pocket cost. This is my 4th Silverado and will be my last...
It is the 6 speed.
Should be hearing from the shop today what the damage is.
What exactly did you go through before going down?
Was your shop a dealer or a local independent?
Mine started with a couple incidents of low intermittent whining noise when shifting gears one evening when driving home from work (happened twice for a couple seconds each). Drove it to a dealership the next day and they told me I needed a total transmission replacement (without even opening the transmission). So I opted to take it to a second local independent shop for a second opinion and the truck broke down before I got there (transmission/torque convertor just would not engage). So it went from driving normal to stranded on the side of the road within 24 hours. Independent shop recommended total replacement transmission replacement as well.
After my experience, a coworker took his 2015 in which had 75k miles to have the dealer "check" the transmission. They offered him a fluid flush/replacement service which came with an extra 30,000 mile warranty for the transmission. May be something to ask your dealership about if it is not toast already.
Also, I wrote a letter to Chevrolet Corporate outlining my current problems and long history of owning Chevrolet vehicles. They did respond but denied any form of reimbursement because I had an independent shop perform the work and not the Chevy dealership.
I am interested to hear how yours comes out. Please keep us updated.
I didn't get the whining noise but did experience the exact scenario listed in the pdf below. Then it went to nothing in my driveway. No drive or reverse.
42 minutes ago, UrbanRage said:
I have a 2017 5.3L 8 speed and was experiencing the same issue. The dealership flushed the transmission which has seemed to correct the problem.
https://static.nhtsa.gov/odi/tsbs/2019/MC-10163890-9999.pdf
Hope this helps.
That pdf describes exactly what mine felt like. Drove it like that for a couple days, then it wouldn't shift at all.
Has anyone had any luck recovering cost being outside of warranty?
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 634 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
