15 minutes ago, Gangly said:
I guess I've never had an issue with water getting in the bed of my truck through the tailgate and ruining anything.  I completely understand the worry though, I'm OCD about certain things as well. ?
Do you have a tonneau cover?  With mine off, I can drive gravel roads all day and there'd be a bit of dust in the bed and on whatever I had in there.  With the cover on, EVERYTHING in the bed is COVERED in dust.
I don't think this is about being OCD.  It's about how the bed sucks in air around the tailgate when you have a tonneau cover on.
I have a soft topper that I keep on the bed and have very little dust intrusion and rarely do I find any moisture anywhere in the bed.  However, I know its not vacuum tight above the tailgate and that might be why I dont get dust and stuff sucked in from around the tail gate seams. Either way, its nice to know there are solutions to the apparent issue.
This. My tailgate gets dirty quick with the bed cover on and stays clean as the rest of the truck when it's off. The aerodynamics change so much with the cover that the vacuum behind the truck pulls in water/dirt/dust. It makes me wonder how the bed cover affects fuel mileage.
On 1/4/2021 at 7:43 AM, mjonesjr84 said:
How does it do with keeping dust and water out of the bed? It looks like it doesn't do anything for the vertical portions of the tailgate.
I had this put on my 2020 Trail Boss, took it off within the first month.  It doesn't seal anything when the tailgate is closed.  It is only useful in keeping mulch and such from falling into the tailgate crack.  It was still a pain to clean out so I decided to take it off.
You also can't have it installed and try and seal the tailgate while closed with any type of gasket because the two would interfere with each other.
I have bought the ESI Ultimate Tailgate Seal from Amazon, but haven't installed yet.
These gaps on the tailgate are getting huge!!
I got this one right before I made this post. I haven't gotten it installed yet either but probably will this weekend.
AmazonSmile: Lund 30002 Genesis Tailgate Seal: Automotive
  • 3 years later...
In my experience, water mostly entered when going thru my Carwash.  The vertical water jets that go around the back of the vehicle soaked the inside (Left & Rt Sides).  I have a topper and a bed mat inside, keeping it dry is a nice thing, especially when loaded with tools or camping gear!
If dry and dust-free is a requirement / issue the stuff should be in the back of an SUV.
Even if the tailgate doesn't leak there are still holes in the bed.
Edited by redwngr
Sides of tailgate do not have water seals so water will get in with the side blast of the car wash.
I am wondering if this would help or hurt me.  My 2017 had a bed rug that covered tailgate as well.  In winter the section that covered the gap would get wet and freeze . So it did not hinge well.  I assumed it came from bottom but was not sure.
I will probably order a new Bedrug in the next week for my new 2024. Been thinking about getting the version that does not cover tailgate because of that.
Edited by rrmccabe
    • Okay boys and girls I put a bottle of this in Dizzy the oil burning guineapig after a tank between the coil and plug service of the #3 hole and near the end of the first R&P 5W30 attempt. As a note I did a two R&P oil changes back in October of 2025 with little effect. Granted they were 1K mile a shot oil changes so.... Then followed by fourteen  1K mile changes of Mobil 1 Euro 5W30 FS. Also ineffective.    Anyone who has followed the adventures of Dizzy may remember that to put the oil on the full mark of the published nominal 5 quart change I withhold about a cup of oil. That over the last 50K miles the P0420 light has been a frequent flyer, sometimes three of four a day. And that even on 93 octane fuel she registers some KR even in moderate conditions on favorable days on slight inclines. Lastly when giving her a kick in the pants, something done about once a week, she looks like a diesel with the pump turned up. 😬   After one bottle and over the last 500 miles of a 3K mile OCI, of the first oil change I dropped the nastiest looking oil ever in her history. That's saying something as  you will recall I have used AutoRx, HP EC30/40 and a few other harsh solvents in her before including the GM top soak twice. This was syrup. Black stinky, inky syrup but the filter wasn't all that bad.    On the second fill I had to use the entire 5 quarts to reach the full mark. That was unexpected! The ignition KR is completely gone! Even at 99% engine load. MAP is much lower. Level road is now 9.8 instead of 12.5. Fuel economy is remarkably higher and for the first time since her earliest days she will spin to 6500, more than a thousand higher with out laying down dead. Yes, the coil and plug had something to do with that but remember the first 2500 miles after that repair on the first change it was same ole same ole Dizzy. Seems we have top rings that are somewhat functional again. P0420 code only comes on now if run in town for more than an hour of stop and go. On the open road it goes weeks without a incident. Perhaps it is cleaning the cat on the pass through?  Fuel Trims have improved as well. Nothing not to like.    To early to say about oil economy but the changes to date in the operational aspect is remarkable. I can't think of a worse case than Dizzy.... It's already paid for itself in a few tanks of fuel with the mpg improvement.    @OnTheReel, I'd say if the Jeep didn't respond perhaps there wasn't an issue to respond to.    I've run the Red Line SI-1, AMSOIL fuel cleaner, GUMOUT and Techron all in this SUV without any such results. Color me impressed. I'll be running out my supplies of the list mentioned and moving on to the Valvoline R&P Fuel System Cleaner.
    • Hey Chuck !!Thanks for the all the info I'm an old fart and I have everything I need for the oil change at home,minus flexibility .... and I’ve been doing my own oil changes for 40 years. I just didn’t want to end up without a crush washer or with the wrong one in my stash and have to walk to the auto parts store, lol. I climbed under the truck to check the location, and man, it’s going to be the easiest oil change and filter swap in the last 40 years—right up there with my 2014 Mitsubishi Outlander 2.4. No mess, nothing to drip on—just perfect. I’ve got one more free oil change to use, and then that’s it with the dealership!
    • I think this subforum was created for the new generation pickup trucks (2027-) with the 3.0 but I don't think it's a big deal either way. There are probably 2027 model-year specific changes for the SUV's too.   I was just curious if you had issues with your 2025 3.0. I'm still under 10k miles on mine and fingers crossed I don't have thrust bearing issues. I'm guessing not, since you're willing to buy another one! It's a good engine minus one or two manufacturing whoopsies.
    • Wife has enough metal in her she hides from the scrapper.
    • Djannoyed was a one hit wonder. Posted and disappeared.
