Hey members. I need some guidance. I’ve been doing some homework but want your feedback. Looking at 2 travel trailers. One is 8200 dry weight other is 8700. My truck is 5.3 liter crew. I think tow capacity is 9400lbs. Weighed my truck yesterday it was 5900 lbs. I know this truck is not really what we need to haul these trailers but I just don’t really want to part with my truck. I have to buy tow mirrors also buy the trailer braking switch and harness because truck wasn’t built with max trailering package. It’s 3:42 gears. What should I do? I know people will say 2500. Diesel. 6.2 liter. 6.0 liter etc. what is your opinions? What about 4:10 gears. It does have level kit and 33s right now. Any insight would be appreciated.
Thanks
Flash
Keep in mind that the trailer will be 1000lbs heavier than the dry weight. My 32' is 6700 dry but 8000lbs on the scale. If you are set on the truck I'd probably try to compromise here.
I'm assuming you have a Z71 which are going to have softer springs and not enough payload for that trailer. I have 1916lbs payload with max tow and run a little over 1800lbs when truck is loaded and trailer hooked up.
Tire and suspension upgrades (upgraded springs or airbags) for stability. Assuming that you have the 6 speed, the 3.73 gears are what's found in the max tow.
I've seen Z71s pulling larger trailers so it can be done. I don't know how well it does or how long the truck can do it.
Sent from my Pixel 4a (5G) using Tapatalk
I'd imagine things get real interesting fast if one has to stop quickly in a panic, probably won't.
Then you need to look at some different trailers.
Your truck would get those moving, but you will be white knuckle driving and God help you if you encounter cross wind or have to stop in an emergency. Suspension and brakes on 1500 are not designed for that.
News flash, Flash.
You answered your own question.
I know this truck is not really what we need to haul these trailers "
My truck is not a Z-71. I know I answered my own question and knew what I was gonna hear but just wanted some insight I guess. Keep it coming.
Thanks
Flash
I'd recommend two things - first is make sure you have a weight distribution hitch with sway control.  The Equalizer brand is probably the best out there, but not cheap.  I prefer the Curt brand which is also a high quality product.
Second item would be looking into suspension assistance if towing thay close to the limit.  Roadmaster Active Suspension is the best choice.  Airbags and other solutions are available too.
Last thought would be, you may be searching for additional power in some cases and so you may care to purchase a tuner or have Blackbear do some custom tuning for you.
I can tell you now that you will not be happy towing that large of a trailer. I have a Rockwood MiniLite that weighs much less and I'm happy but would not want anything heavier or longer. If you decide on gears go with 4:10, guys on the RV forums swear by them making all the difference in the world. Air bags will help but they do not raise your capacities.
The 5.3 and 3.42 gears tells us you don't have the Max Tow package and your GCWR is 15,000 lbs.  If your truck weighs 5,900 lbs on it's own, that leaves you with only 9,100 lbs for a trailer, passengers, and cargo.  Advertised dry trailer weights rarely match actual trailer weights.
Either pick a smaller trailer, buy a bigger truck, or be sure to post on here anytime you're towing so that us responsible motorists can avoid encountering you on the road.
https://my.gm.com/content/dam/gmownercenter/gmna/dynamic/manuals/2015/chevrolet/equinox/CH-CAT-10217126_MY15 US Trailering Guide_122215.pdf
Edited by Salsa De Piña
After an accident when insurance companies discover things like this they either cancel the policy outright or just cut a check and say "see ya!".
Weight distribution hitch, air bags, brake control, and at a minimum 4.10 gears. Sometimes when me and the family go places I end up pulling a 4 horse living gooseneck with my 3500, and the daughter follows in her 1500 5.3 pulling a trailer that on the scale is usually 10,200lbs. She does have 4.56 gears instead of 4.10s, but has never had a problem pulling the trailer. Mechanically there hasn't been any issues and she is at 146k miles.
If you are comfortable towing the weight then go ahead and tow it, if not go with a lighter trailer or bigger truck.
Sent from my SM-G975U1 using Tapatalk
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
