I found a little shop in Missoula with a good reputation, and he's going to try and figure it out. It seems I'm just getting the P00530 code now with the running poorly after it is driven, shut off, then run again. I'll suggest what you said to him and see what he says.(If the wiring for the O2 sensors is good, then it is time for a new ECM.)
Hi everyone. I took my truck back to the Chevy dealer today, and the still insist it's the Cats causing my problem. They said they found codes PO155 / P0059 / P0050 / P0154
Here is their Diagnosis.
Please let me know what you guys think. I trust you more than these guys. They want $1750.00 just for a Y pipe ..... plus installation.
Hi guys . I took my truck back to the Chevy dealer today, and they did a free diagnostic. They are still insisting it's the Cats causing my problem. They said the got these codes.:
They want $1750.00 for the parts  plus labor to install the Y pipe.
I trust you guys more than ny dealer at this point. Let me know what you think now.
I think we've exhausted our opinions on this. I personally don't think it's the cats at all.
I think you are right Cameron, and I don't relish the idea of another $2000 to install cats and not fix the problem. I talked with a different mechanic shop, and they want to look at it next Friday. So from what you have said, and the fact that both Oxy sensors responded when they squirted brake cleaner into the intake and got 800 MV spike, maybe it's the ECM.
Again, these codes are o2 sensor heater codes only. Nothing to do with fuel trims or convertors. Strictly an electrical issue.
Edit. P0154 is not a heater issue. The other 3 are.
DTC P0154
HO2S Circuit Insufficient Activity Bank 2 Sensor 1
DTC P0050
HO2S Heater Control Circuit Bank 2 Sensor 1
DTC P0059
HO2S Heater Resistance Bank 2 Sensor 1
DTC P0155
HO2S Heater Performance Bank 2 Sensor 1
Without a p0430 code I'm not buying the bad convertor diag.
If it were me, I would go after the 3 heater codes and see if I find a related issue with the P0154 code.
Not sure if it still holds true but it had been true that you always start with the lowest code first. The only way I see a convertor causing an oxy sensor code (P0154) would be a plugged convertor. Not likely given their age.
Edited by tbarn
I'm between a rock and a hard spot on this. I thought the dealer would be able to figure this out. My only hope now to get this solved is that the new mechanic next week can get to the bottom of this. This has gone on way too long.
Well, the dealer did figure it out, you just don't trust their judgment.
Yea it would but don't be under the illusion that it will magically tell you what is wrong. It takes the tool, knowledge of how to use the tool, and probably a diagnostic tree. Maybe you can handle it, I don't know.
    • I was the GM of a Lincoln Mercury dealership back in the 80's. The service lot was always full with "broken" ones. Plenty of transmissions, power windows and a/c repairs. The only one I'd consider owning would be the Marauder at this point and it certainly wouldn't be a daily driver.  My 2025 GMC Sierra 1500 Denali Ultimate is my "Lincoln Town Car" in my retirement. I want all the "stuff". Big infotainment screens, one touch power windows, Supercruise (I won't buy another vehicle without it), hands free pretty much everything. I'm going to swap my current truck for a 2027 Yukon Denali Ultimate so I can have the air suspension and surround vision recording along with all the other "stuff".
    • Yep mine is on backorder also.
    • The Denali Ultimate's grille is tinted, but the "regular' Denali has a bright chrome grille like the current models.
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
