I will have my truck in a few weeks, so I haven't gotten to listen to this system yet.  But if it is like the Bose system in my 2013 Camaro (and my previous Silverado), adding a sub is all that I needed to be happy.  Adding the sub allows you to reduce the bass output to the other speakers and give you more room (ie: volume) before you start getting distortion.
On 2/21/2021 at 5:34 PM, Pswa320 said:
So your using the bose up front and kickers in rear?
Yes sir. The rears still don't produce any bass but at least you can hear the highs now.
On 2/22/2021 at 8:48 PM, GS357 S said:
This sounds like a great solution.  Were the JL Audio a direct replacement speaker for the factory Bose?  Did you lose some power assuming you went with a higher ohm speaker?
I ordered from Crutchfield who provided the adapters for mounting and wire harnesses. I also used window caulk around the  mounts to prevent vibration. Definitely did not lose power. Can turn the volume up significantly higher and still have clean sound. Substantial improvement over the Bose speakers
On 2/22/2021 at 7:50 PM, Dunn said:
I just ordered this exact same setup from crutchfield today for my elevation...like $300....I dont need a stupid auido system... just want a clean sound and dont have to crank volume, i know you can get crazy with these things
good to hear your happy and I dont even have the Bose, did you do it yourself or have it installed? and did you dynamat whole door or just where the speakers are?
Installed myself. I’ve always just put the dynomat on the interior (actually backside of external part of door) metal, never on the interior door panel (plastic). I did as much dynomat as I could reach.
Would replacing the stock “non Bose” speakers help at all, or since there is no amp without the Bose system, I would really need an amp?
The doors are actually really well deadened from the factory. I added some (as well as some Dynoliner on the door panel back to mitigate rattles) but it didn’t need a whole lot IMO. Think there are bigger advantages to using it elsewhere such as the floor.
Changing just the rears on my Bose brightened it up quite a bit back there. It was necessary because the Kicker sub was really overpowering back there when the back speakers did basically nothing.
I was eying these mini amps up which would probably help even more, but sort of hear mixed reviews and I’m pretty much ready to move on to the next truck:
https://www.crutchfield.com/S-kctCW6cqCMO/p_575PM100X1/Rockford-Fosgate-PM100X1.html?XVINQ=GLX&awkw=216564569785&awat=pla&awnw=g&awcr=111687883825&awdv=m&awug=9018811&gclid=Cj0KCQiAj9iBBhCJARIsAE9qRtCqzgLjQ3aEYtmMpDVAKzJAhTUYop0h5V1he2JS1IdVp7X8Gl0htDEaAu3fEALw_wcB
this is what i am about to do, my speakers just came in today....look very nice and magnet is much bigger.....
also they are suppose to work great without bose system, it seems like it has plenty of power just crappy speakers.......i had HD radio in my last truck and it was marginally better than what we have in elevation.....think any decent quality speaker will be big improvement and if you want even more throw an amp, sub or whatever you want.....stock speakers are pretty cheap
Thanks
Keep us posted on how the factory-replacement quality speakers work out.  Good option to have but I've always gone full build...not sure I want to drop the $$$$ yet.
So reading through this, I think the sub is pretty decent, but I would really like better mids, and especially clearer highs. Did you just drop the JLs in using the Bose power?
Edited by Donald Plaisance
answered my own question
I recently added a 10" sub and amp. I find myself turning down the bass knob quite a bit. i also added audio frog gs25 up on the dash and that really helped out with clarity. i deadened the rear doors and added the c1. they are a lot clearer than stock but aren't really loud. next up is sound deadening the front doors really well with soundskin and see how that improves the stock 6x9 before i decide if i want to swap those out. they don't sound bad now. i do have the radio eq bass set at -8 or so
i put in the doors and its a bit better but not huge.....i didnt do any sound deadening and just slapped them in really quick as i was in a rush (stupid and i knew i should have waited and did it right).....i still have tweeters to do and will redo doors with dynamat, weather seal, and foam surrounds......i am sure an amp would help as the bose has one and mine doesn't have one or not that good....
for now tweeters and I will refine the door install to help....see where that ends up
i really notice the tweeters now where with stock speakers they didnt seem to stand out so much from the rest.....
the plates behind door handles are really fragile and tabs break super easy FYI.....
From what I've read, the base radio is awful.  And yes, I would plan on an Amp and speakers.  I can't see the base radio having the power to drive a good speaker.
Having said that, you could upgrade the speakers and then see how you like it.
Edited by Jim E
If you want a good sound system I would think that is probably best.....not sure stock speakers could handle an Amp, or for how long......
Sure mine will sound a bit better doing things I mentioned I would do but yeah believe it needs more power.....  am sure there are plenty of qualified people here in stereo modifications here....I am not one, lol.....just the basics
Type of  music you listen too as well.....
Still glad I have better speakers though it just wasn't that big a difference
    • I tried tapping it.  This might sound like a dumb question, you should feel vibration or some type of noise when it turns on? Can someone please verify? Thank you all!
    • I feel better now for my own view point and actions or lack there of towards the dealership service theme reading your post and others. GM corporate is who offers the two free oil changes on the HD trucks and I bought my truck in Feb of 2025 and those oil change offers run out within 2 years I believe and I highly doubt I will be using either one of them. I had asked if I could officially give those free services to another customer ( a friend ) and they said no, its all a GM corporate thing based on the vehicle in question. What that service advisor did however was go into a little story about how such and such customer was denied engine warranty because he had done his own oil changes because then they are not documented ... you see where that goes and so an employee playing the game of scaring the customer into having the service work done there most certainly triggered my thought process. At a later date I did talk to the person who handles warranty claims at the dealership and she said to be sure to document the oil changes and keep receipts for the oil and filter ( coped the receipts from cases of Mobil oil and case of filters I bought from them ) and the vehicles VIN, the date of service, mileage etc and staple that together as a record I would give them if that was ever needed and I keep my own log book for services for each vehicle as well. Oh and about 8 months after I bought the truck the dealer starts calling me to offer a maintenance service since they haven't seen my vehicle show up on their system ... for the mere fee of 300.00 Canadian to change the oil and rotate the tires and a few other minor checks and I declined the offer, I get the call again a couple of months later for the same thing and she could tell I was not interested and she asked if they should take my name off the call list and I said yes, do that !.    By the way did you happen to keep your factory oil filter to open it up and see the surprises inside as I expect some will show up as per the odd little sliver of metal shaving and particles that the filter does trap along with bits of grey silicone sealer that come off of the inside edge of mating surfaces. I have cut open every filter so far on my truck although few miles but have changed the oil often and the second filter was vastly better with very little of anything, that first filter was the unsettling one as I expected it would be.
    • I get why they do this…but man…not ideal. I only extract on inboard boat engines because the drains are buried and even then I hate it because it’s easy to leave a quart behind with that method.   They should market it as an “oil refresh” not oil change!
    • I only get oil changed where I can watch. Valvoline pulls through the dipstick into a see thru glass. When done they show me the dipstick. About the only way they can mess up is using the wrong oil. But that secret wouldn’t stay secret long. Honda uses TQ wrenches on everything. You can watch through a plate glass window. Discount tires does that with tires. Trust but verify.
    • I would not argue that with you. It would be pointless to argue against the truth and you speak the truth.    My question and in fact the entire point of this thread is an exploration into the levers of wear which happens no matter how well we maintain our powertrains.    Some of these levers we exert a good deal of influence over which can and do result is lower wear, longer powertrain life. Some others we are sort of stuck with.    An engine is typically done when the ring to bore seal no longer is able to do the job effectively. Normally the first thing to go in a engine otherwise well maintained and adult driven is this seal.    Looking into the means, methods, products and attitudes that influence the rate of wear seems a worthwhile inquiry to me.
