Drove to the hospital for a scheduled test and when I shut the truck off in the parking lot I got notification of an update. Then the radio didn't shut off when I opened the door. I cancelled the update until I got back home in my driveway just in case...
The update took a little over 10 minutes and I have no clue what it included. I have not had any issues with the truck other than the radio staying on before I allowed the second update to complete.
This is the third update since I bought the truck new.
What AnacortesArmyGuy said but I am curious.. what version are you on now?
Not sure about GM stereos but oftentimes with updates, the way you find out it's coming is someone else got it
On 2/24/2021 at 5:54 PM, AnacortesArmyGuy said:
This link will explain the update.  Though released in November 2020, it's only recently making its way to many of us.  Mine updated last week and took eleven minutes.
https://www.gm-trucks.com/gm-releases-significant-over-the-air-update-for-2020-silverado-sierra-other-vehicles/
It's not the same update from a few months ago.  My truck did the prior update a few months ago and just got another update request yesterday.  Based on other people's posts, mine is usually one of the first to receive updates from GM so I wouldn't be surprised if a bunch more people started receiving update requests.
Well, I can only attest to what happened to my truck, and that is the November update is what was applied to my truck last week.  Matter of fact, it's also the only OTA update my truck has applied since I purchased it last July.
Onstar just released a update also. Look at your Settings - About to see what was updated.
Same here, and maybe different trucks get different updates, who knows?
I've had my truck for a few days over one year and this was my 3rd update for what its worth, 2nd in the past 3 or 4 months.
I recently got an updatand now my phones will not connect via Bluetooth or USB. This happened a few times prior to the update too but it’s worse now.
Frustrating.
@Enough
@Gangly
Can one of you post a screenshot of the version numbers?  I got an update the other day but it was for OnStar
    • Spot on. The government makes ridiculous mandates, and this causes manufacturers to jump through hoops for every TENTH of a MPG. Main reason quality is in the toilet and prices are in the stratosphere.   The gov't tightened the MPG requirements so much 5 years ago that the only way manufacturers could meet these absolutely ridiculous numbers was to go all EV. Hence the push.     Nobody hates good MPG, Atlas - nobody is "whining". Your side has that trait all locked up. What a stupid argument attempt!   What I particularly hate is the government meddling in the free market system. Had this system been allowed to work as designed and intended by our Founders, cars and trucks would be hitting numbers that would blow our minds, all while costing 30% LESS. Not only that, but engines could probably hit 150k miles again without needing major internal surgery.   My forty year old Ford 302 has 312k on it. Wonder what changed?🤔
    • The BORA 3/8" spacers arrived yesterday along with the extended lug nuts. I got the front wheels changed out today, but was overheated and covered in sweat so bad, I figured getting both front wheels done was a win, and took a cool shower. Hopefully, I'll go out tomorrow morning before it gets into the 80+ temps and do the backs. After getting the first wheel snugged up, I backed out one of the lug nuts then hand turned to count threads. I believe I stopped counting around 12-13, so I think I'm good there.
    • My fullsize truck is averaging over 26mpg so I'm pretty happy with the increased fuel economy targets. When I had my gas Silverado (2020 5.3) it was averaging 21. Again, for a fullsize truck, that's very different from the 12-15 these things used to get 30 years ago.   Whine all you want, increased MPG is a good thing.
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
