So my dad has been telling me to go with 22s for my new trailboss. there is a dealer that has 22's oem wheels for 50 percent off for a set near me however I was curious I think it would kinda defeat the purpose of having a offroad truck with 22 inch wheels and I am unsure on how it would even look on the trailboss. Has anyone put 22 inch wheels on a trailboss??? Any feedback would be appreciated
BTW my truck was suppose to be built last week has not been built yet 21 custom trailboss with 6.2 midnight edition
22"s with 275/50R22 all-season are for smooth pavement.
Low sidewall is stiff.
There is a reason GM doesn't offer them with Z71 or with or with either Trailboss
I wouldn't have 22's on one, but it's your truck....
If I could have ordered it with them,  my truck would have 18"s instead of 20"s.
Edited by redwngr
Really should be going with 18 inch rims if you are going to use it off road. 22 will just make it a pavement princess, but hey if you like the look and don't plan to go offroading do it.
See if they will finance the 22's into the total price of your truck, making sure you keep the factory rollers that it comes with. Otherwise they charge you for the 22's, take your wheels and tires (which is included in the price of the truck) and sell them to someone else leaving you with more money owed and only one set of wheels.
That way you would have a set of summer and winter wheels/tires.
Edited by JimCost2014
yeah i dont understand 22s on an offroad truck.....i have 20 and would prefer 18 but they came on it
Before you decide, check tire options and prices.
I have 18’s on my 21 trail boss and I’m curious as to why many people are saying they’d rather have 18’s instead of 20’s. I wanted 20’s but mine only came with the 18. Is it because the smaller rim size allows for bigger tires?
its sidewall of tire....you want sidewall for offroading......to an extreme but still applies in off road in general is look at trophy trucks, rock crawlers, etc....17in rims
 there is more options possibly for 18" rims and cost less......nowadays with big rims becoming popular for show you can find quite a few though......
more sidewall gives you options for airing up or down, reduced pinch flats, reduced scuffing on rims and or rim catching on rock, root, etc and bending of the rim ( either cuz no air volume or spokes being close to ground catching a rock, root, etc).....tire flexes more with more sidewall, also your tire is the very first shock absorber, more air volume is better....its all pluses with no minuses
i have 20s but prefer 18s....ok for now as i dont plan on thumping my truck quite yet
smaller rims give a much better ride as well in general........street wont matter can throw whatever on but ride will be harsher
Edited by Dunn
+1 to this
If you want big rims, don't get a TB
Thank you for explaining that. I never do any off roading really. I went with the trail boss for two reasons. First is it was the only one on the lot in the color I wanted and the 6.2. Second is my dad has the same one in black.
The way GM specs tires, the outside diameters are close to the same with the 18's and the 20's - so rpm per mile stays very close and speedos stay very close.
As well as the differences for off-road use, the stiffer sidewall results in a harsher ride.
Otoh, the stiffer 20" set-up will corner sharper because the stiffer tire has less body roll.  One of the reasons that sports cars use tires with very low profile and very stiff suspension.  Great on smooth surfaces, but sucks on expansion cracks, potholes, bumps or gutters and of course even in mild off-situations.
I've not done the airing down thing I hear about for some off-road uses, but if there is little sidewall.....
Of course all that argument is meaningless if the intended tire/rim system is going to use non-factory tires sizes.
Get what you want.   If I had the money I’d get 22s snowflakes on my GM 2” lifted RST.  Yes, my mall crawler, my pavement princess, my groceries getter.  If I wanted to “off-road”, I can get 18s later.   But let’s be real, if you really wanted to off-road you’d get the Colorado ZR2 or Bison.  IMHO.
    Frank V
    Frank V
  • Who's Online   6 Members, 0 Anonymous, 1,398 Guests (See full list)
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
