2019 6.2 Silverado. 44k miles. Driving on and off all day yesterday then when I left for dinner no power steering. Warning came up on my dash indicating power steering malfunction along with ecs warning. I can't remember  the exact verbiage.  I cycled the power several time with no change. Since people were waiting on us I drove to our destination in that condition and it was difficult to drive to say the least. Luckily we were in a rural area and didn't have far to go but man was I worried about the 120 mile drive home today. After eating dinner I went out and popped the hood to see if it was something physical. Everthing looked good.  Started the truck and everything was back to normal. Been fine all day today. Calling the dealer Monday morning. To think even the most basic systems on these vehicles depend on a computer is sobering. Anything can just quit working out of the blue then work again! ?
Edited by Minnvmax
If you think the computer running the power steering is scary, the one doing the braking system is even worse. My neighbor’s fence almost learned that the hard way. 😬
I’m sure they will pull codes and check for updates, don’t ever remember getting one for steering on my 2019 though. Unfortunately/ fortunately a lot of these glitches come and then go just as quickly. And usually never appear again.
the power steering is weak on the 12volt system
it was not working because it overheated    (self resetting thermal fuse)
Edited by bg1988
  • Thanks 1
That doesn't seem possible unless something is broken. This truck has been through two summers and this just happened parked on snow after driving in cold weather. Dealer suggested waiting on diagnosis since its out of warranty and they were not confident in figuring it out unless I bring it in while broken. At least they are trying to save me money.
Edited by Minnvmax
it was recalled due to low voltage   low voltage can overheat wires easy
GM Recalls Trucks, SUVs for Steering Problem - Consumer Reports
maybe you should have your battery load tested  that would be a good place to start...
also don't forget to file a complaint with the NHTSA
Edited by bg1988
  • 4 years later...
Mine was a broken ground strap between the chassis and body located behind the passenger front wheel ( behind wheel house cover).  They just issued a recall for it
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
