With reports popping up left and right about rust issues with the newly redesigned F-150s, made me wonder if any of you are getting any surface rust underneath your pickup. I remember my 2004, 2015, 2016 Silverado’s/Sierras all had surface rust, mainly on the steel frame, so nothing really to worry about. My 2020 seems to be holding up much better.
https://www.caranddriver.com/news/amp35726969/2021-ford-f-150-pickups-rust-reported/
There was an article in some of the newspapers that Ford made several hundred trucks 2021s and parked them at the airport in Detroit. These trucks were brand new but needed updated software. Ford decided to get a jump on production before all of their testing was done. So these trucks were built and parked till they got around to updating them. I'm sure they were not stored in the most hospitable place either. Which probably is leading to the rust issue.
Undercarriage / drivetrain rust.
2021 Ford
Other brands
They still make the F-150?  Anyway what year because I can't tell the difference in their new one vs the current.  I thought GM was the quintessential  boring same ol, same ol, crease here, flare there?
  • Haha 3
I think i seen this guy's video on youtube, is it the guy talking about surface rust on the rear differential, exhaust hangers and parts, non stainless i might add. If you want it to look factory fresh it requires some effort and of course cash. He also lives in a rust belt state but sorry imo you are beyond nit picking if you complain about exhaust hangers showing signs of rust. It's called fluid film, and also a lot of elbow grease and time to keep things clean, either do it or stop complaining about something that is well out of fords or any manufactures control.
He’s nitpicking for sure. But to be fair, after 3 winters in salt my diff and exhaust hangers don’t even look like that. And I’ve never painted or undercoated them. I’d probably be a little annoyed too.
It’s a Ford. Go figure!  Let it rust. Never been a fan and never will be. Too many on the wife’s side that think they are superior trucks in every way.  I haven’t seen it yet. Never been impressed.
It's on the the rear axle. I heard the early launch vehicles didn't get any anti- corrosive coating on them as they were in a hurry to release.
I read that too.. Still embarrassing.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 2,015 Guests (See full list)
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
