Hey all. My wife is in the market for a three row SUV. Does anyone know if any of them have ventilated seats in the second row?
We live in FL and it's always hot, so just looking out for the kids (first world issue, I know).
It's hard to Google since the searches primarily bring back vented seats in the front.  I think I saw the Kia or Hyundai have them, but not a huge fan of those, even with their very strong reviews.
Would love to stay in the GM family with the new Tahoe, but an Explorer/Expedition would work too, or even a German brand.
Thanks in advance.
Thanks in advance.
Yes, depends on the package of course. Sorry this is only showing heated in the 2nd row, let me check the GMC site.
Edited by JimCost2014
Order guide also shows heated available for second row -- but no mention of ventilated.  Even on Escalade ESV
Rear air seems to be standard.
We just bought a Hyundai Pallisade. Don’t knock it until you check it out.
We’ve had 4 Hyundai’s. The first 05 Elantra 3 generations have used it. My grandson is still driving it. I’ve drove as a person vehicle a 2010 Genesis coup and a 3 row Santa Fe. My wife daily drives a 2011 Genesis sedan. Her next one will be another one.
Yeah no GM SUV has ventilated 2nd row seats. Very strange.
I bet we'll see them in the 2nd rows on the High Country and Denali (maybe AT4?) trims in the 2022 truck refreshes. So then maybe they will rollout on the 2023 SUVs in the 2nd row.
"Ventilated seats" sounds like a great option for a family stricken with flatuence, IBS or swamp butt. [emoji848]
Or lives in Texas, Louisiana,Mississippi, Georgia or any state it gets above say 80 and parks on anything other concrete. Or maybe concrete too. And of course has leather seats.
Amen brother (typed in Houston)
Bingo. 🙌🏼
Since most of the trucks for sale these days have gone to all-black interiors, this is even more important, IMO. It's the one feature I really regret not having in my RST. My next truck will for SURE have ventilated seats. Having a sweaty back just from driving to the office from lunch is not cool. (pun intended!)
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
