I had this happen to my 2021 GMC Elevation a couple days ago. I wanted to include some parameters to hopefully help us narrow down a particular cause. when this happened I had been driving for over 15 minutes and stopped at a friends house to drop off a phone. His driveway has a steep incline so I was parked on probably a 15 degree incline. I was low on fuel with 70 miles till empty and I only stayed between 5-10 minutes before trying to start-up. Once I knew it wasn't going to start I held the start button to stop the cycle and it fired right up the second time. 1300 miles purchased in May
Same issue here, I've got about 4500 miles it has happend 4 times now. Taken it to the dealer. Shows no codes. I guess it's time to look into a class action suit. I'll talk to lawyer friend of mind. See what can be done. Will update if we have options.
Yep, something needs happen to make them start giving a ****** about the problem...  They have no fix for this and it's a super common problem...   I don't understand why it so hard for them to fix this.  Sound like they gave Gruggas a new truck, take his old truck apart and figure out WTF is going on.
My Sierra 3.0 cranked 15 second or so with no start a few days ago.   It started normal the next try.   It has 2400 miles.  The truck was built in Mexico 3/21. Took it into the Dealer last Friday.  On the drive before it had the cranking problem, it threw a code, P059F which cleared itself on the next restart.   This is a code for a circuit problem in the actuator for the radiator dampener motor.   Dealer confirmed the code I listed and order parts to replace the dampener controls.   Said they never heard of the starter problem and were unable to make it do it during the hour they messed with my Truck.    I told the service manager about the existing TSB for checking the cam sensor wheel and other things I had read.  He basically said they would read the codes and go from there.  Since this problem does not set a code, the dealer is helpless in solving the problem.
Saturday I torqued the fuse box.  It was very loose.   It took several turns on each screw to even get to 40 in-lbs.   I really doubt that these fuse boxes are not torque down from the factory.   I believe the plastic housing deforms with heat cycles.   I suggest anyone with one of these new Silverado or Sierra get a 1/4" torque wrench and a 7mm sock.   They should torque the fuse panel whether they currently have the problem.   I am willing to bet that these bolts will loosen even after I tighten them.  It may take of few months, but plastic is plastic, ie it deforms which is why it is called plastic.   The black plastic used for most of these parts is filled with fiberglass to make it more rigid.  These part are generally 30 percent fiberglass and 70% Nylon.
I suspect the code for the dampener could have been a result of the loose fuse box.  I'm not going to let them change the dampener parts until it throws that code again, if it does.   GM needs to train techs to troubleshoot not just read codes and replace parts randomly until they fix something.   This method of repair is more a business model to maximize income for the dealership than effective problem solving.
BTW, these are really nice trucks when they work right.  Mine is getting around 26 mpg and it is crew cab 4wd.
Gerald
Just picked up my new 2021 Silverado RST 3.0 Z71 Crew on July 9th. Fast forward to this morning July 11th and after sitting in the garage all night had the "Start Issue" only 120 miles. Sounds like there is no fix at the time, just have to wait and see. But I must say I really like the truck.
   Sorry you are having issues right off with your new truck.   Hopefully, GM is getting close to solving this.  I noticed Consumer Report recently downgraded GM full size truck reliability and recommend avoiding them.   This should amp the pressure on GM to solve this and other mostly electronic related issues.
I have a 21 Silverado 3.0 RST Z71 4wd that had the 20 sec no start crank for the first time at 3600 miles. Started right up the 2nd time. Thanks for the tip about holding down the push button to stop it. Been getting my camera out each time I start it now so I can show the dealer what it is doing. Hope they fix it because I really love everything else about this truck.
13 minutes ago, Matthew Capobianco said:
Just happened to my 2021 Duramax AT4 has 1030 miles on it, continued to try and start for 20 seconds then shut off.  Let the truck rest a minute and fired right up.  Did not utilize the key fob to try and crank.
With my truck I did it both ways, with the key fob and with the button in the cab.
Same issue, 2021 Sierra Elevation 3.0 1,200 miles.  This is the 3rd time in the shop.  They found a bent trigger wheel, its been in the shop for a month waiting on the part.  Parts manager just told me the supplier is re-engineering the part and no delivery date.  I am beyond frustrated, i have called gmc customer service and been assigned to a "specialist"  who never has any updates.  Im currently stuck in a small SUV as a loaner.  At this point GM service has had the truck longer than i have.
You have to call this number and insist on speaking to someone, tell them you do not want to be transferred to an extension, you want to speak to someone (was on hold for 45 minutes until I actually talked to someone)... took me 8 days to actually talk to a specialist.  As of now, they are paying my truck payment for June due to being in the shop for 16 days that month.  Have the truck now... has been in the shop 2 times.  According to the specialist, 1 more time and they will purchase the truck back.  Depending on what state you are in, 30 days could be the point of purchasing your truck back.
I dont want a buy back situation as i was able to get a pretty good deal on the truck.  They arent offering the same rebated that they are now.  Was yours the trigger wheel?
Sorry for not updating fellas. So, after losing my mind on GM, we came some sort of agreement. I’m not 100% happy and that they fixed the problem, but I ended up keeping the truck because it’s everything I wanted and they gave me a BUNCH of stuff to keep the truck. A new sister to that truck would have taken forever dude to parts shortages. After the 3 time the issue happened, I took it to the dealer the next morning and the did a huge update to the ECU. Since then, no problems… for now. I’ll keep you guys posted if anything else happens.
I hope that fixes it, but they updated mine and it did it 2 weeks later.  Curious what incentives they gave you/...
What was the "bunch" of stuff....
    • I have a 2015 Silverado and sometimes I can not get in to the truck. I use the key to unlock the driver door. Something is locking the truck when I unlock it, last night I left the truck open and this morning it was locked with the mirrors folded in. This happens while driving so it is now a safety issue. I reach down for the folding button and they open, then they close again.  Any advice, thank you,   Ed
    • Did you ever find a resolution to this? my 2019 Silverado 1500 is showing the exact same headlights issues with the exact same symptoms.  would help a ton if anyone has any advice on this or better yet a known solution..
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
