On 3/29/2021 at 7:08 AM, PuffDr4gon said:
No, there is no designated place. You can place it wherever you want.
I routed my wire along the sub wires and then under the dash. Used double sided 3m tape to place the knob at the bottom of the center console. IMO, came out very clean.
 That looks really good! I will likely to something similar. The spot I'd really like to put it is in the blank space between the home/reverse and forward/back buttons right below the screen, so its at least physically grouped with the rest of the audio controls. It would also do something with that empty filler that looks like it was supposed to be something but at the last minute some designer decided they didn't know what to do with it and just put a plate over it. While I can't say its impossible to do, I've had the radio stack out a couple of times to look behind and the prospects don't look so great. I would have to take a closer look to be sure, but I think where you located yours is a safer bet.
Hey guys- are you installing this sub in a truck with or without Bose? I have Bose but would like a little more bass. Too much bass comes through the speakers currently..
Mine is with Bose.  It seems to take the load off the crappy speakers and puts it on the sub.  Overall it all sounds better.
Did you get just the 10” sub or the option with the amp kit?
Edit: wait if I already have the Bose, I don’t need the amp kit version right?
When you enter your VIN on the Chevy/GMC accessories site, it tells you which one you need.  I have the Bose system and the Kicker sub comes with an amp and sub.
The expensive version with the DSP amp (which powers all the speakers) is for non-Bose trucks ONLY.
The standalone sub kit has a small amp attached that runs only the sub. It can be used on either Bose or non-Bose trucks and has instructions for both.
It takes a bit of the bass load off the door speakers, however since the EQ turns the bass down on both the door speakers AND the sub, there’s no way turn the EQ WAY down without losing bass from the sub as well. But between the knob, the dip switches, and the EQ, you can definitely get it sounding better.
My Kicker kit arrived as did the knob. With the Easter weekend here I doubt I’ll be able to carve out some time to get it installed. Might have to sneak in the garage and do it when everyone in the house is sleeping. The itch to get it done is now a full on skin clawing scratching!!!!
  • 2 years later...
Hey Justinshort, I didn't see a knob in mine.  Kicker knobs are fairly cheap to buy on their own but the next question is, is there a port to plug the knob in?  I don't have my truck to verify at the moment.  I'll be getting it back later in the week and report back.
Edited by reese
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
