Hello everyone. I am interested in doing the rear view cam mirror mod that is listed here and about to purchase all the parts. I also want to know if its possible to add a front facing camera too or will that need something to be reflashed by dealer or WAMS?
2019 Sierra 1500 AT4 without 270/360 cam. Only have rearview cam
45 minutes ago, lapoolboy said:
Don't order one.  I have one with harness.
Question is, is it possible to do it with what i have stock with the truck or will it need to be reprogrammed?
and when you say dont purchase one because you have one, are you sending it to me :)
31 minutes ago, Mac-427 said:
Here is the approach I used.  Not exactly what you are thinking of but it works well for me.
Thanks but not something i want as I do not have a front plate nor would I want to use a phone as a ponitor
I did something similar with a wireless camera from amazon.  It was part of a camera setup I installed for towing my travel trailer.  After I sold my trailer,  I also gave up my dependence on cameras.  Pickup trucks have always been a challenge to park but with practice (and perhaps a few bumps 😉 ) you can get pretty precise with the placement of your front bumper.  I'm not adding this as a criticism to camera technology as my next vehicle will have 360 view!   When you watch the coming and going of trucks in a crowded parking lot you'll see some drivers park their trucks like it was a smart car.  Others, need two stalls and several attempts to dock their trucks.  I like to challenge myself to park quickly and precisely using only my windows and mirrors.
If you wanted oem camera system it would be hard to add on a truck with no VCM but might be possible if you had ios or iot radio.  I had an RST with a VCM because I had bedview package.  A truck with only rearview cam does not have a VCM.  I was able to add oem front cam by swapping VCM with a 360 one.
Which one did you use?
I bought the Haloview wireless system with 7" monitor/recorder and camera for behind my trailer. I added their licence plate mount camera for my front view.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
