Has anyone here serviced the differentials and transfer case? Just picked up the GM fluid Dexron VI for the case and the special high efficiency front and rear diff. fluid. 10-4091. Guess there is not a drain plug for the front. Do a lot of towing want to change out fluids early.
I haven't performed the tasks yet but I was planning to at 50K miles per the requested service interval in the owners manual for the transfer case.  Are you sure there is no drain plug for the front differential?  I haven't looked yet, but that sounds pretty odd as they are regularly maintenanced item I would think.
Let us know how it goes since I plan on swapping out fluids for all three items in the near future and it would be great to have you as a "test mule" :)
Cover has to be removed for the front axle and rear axle.  Gasket is not re-usable for either one per the manual, must be replaced.
The rear axle seal was re-usable (RPO SU7).
Front axle was not re-usable, $13 gasket, there are some wiring harness tree-clips(not sure exactly the clip type) on the cover itself at the 11ish-oclock location. (RPO SU4).
Hmm.  Service manual shows for all axle RPO codes that the gasket is to be discarded and replaced with a new one.  We haven't had any open for maintenance at work so just going by the GM manual.
Edited by newdude
If i were to do it again (in another 28k miles), i would buy the rear/gasket axle seal (probably $15). It was the same style as my 2005 canyon and the dealer told me that it was a re-usable seal/gasket, and i assumed i could re-use it. i have roughly 2k miles on it now and no leaks. I did clean it really well and kept it dry (per instructions on the internet) while reinstalling.
I changed out the fluid in the front and rear differentials.  The front I sucked out since the harness for the power steering and other stuff was in the way.  I didn't feel like messing with that.  The rear I pulled the cover off, cleaned up the magnet and put it back on using the original seal.  So far 20k miles no leaks.
I also did the transfer case.  I can say that the AMSOIL Squeeze Packs work awesome.  No mess to deal with.  ATLPK.jpg.fb00cd16dad10fbbbfff09628592dae5.jpgSVGPK.jpg.a44b53c3dbfd47484128b8391cc3860e.jpg
Edited by Black02Silverado
  • Thanks 2
  • 3 years later...
10/30/24
Today I had a fight with the chev dealership about changing the axel lub front and rear. They said and I quote, we just remove the fill plug and suck out the oil and put in new. To remove the cover is old school. I said to them after getting a full refund " if you want the job done right, do it yourself". More and more i hear how all dealships riping off people more and more. This is third world crap and it's time to call them out on this .
I see nothing wrong using suction to remove fluids. I did it with my transmission on  my avalanche and if it didn’t have a drain plug on the differential I would have done it there too. It cuts down on the mess. If you wanted to inspect it still would be less messy. If you had asked for an inspection of the gears they probably would do it and charged more money. I don’t see a problem.
10 hours ago, just just said:
10/30/24
They were being honest since electronics wires bundle is in way.
What does the service manual say about service interval for front/rear differentials on the current generation?
A few years back there was an interval in the owners manual, instructions on method and a list of fluids to use.
St
St
Looking at the 2024 owner's manual for a 1500, the only fluid they call for a change interval for severe use is the transfer case every 50,000mi.  Oh and transmission every 45,000mi.  Normal use, transfer case every 100,000mi.
For 2024 HD, normal use its transfer case every 50,000mi, severe use its every 25,000mi.  Transmission is only called out for severe use, every 45,000mi.
Neither schedule calls for front and rear axle lubricant replacement.  I even went back to 2010, no diff servicing mentioned then either in the maintenance charts.
Thinking on this, AAM was sole and is still a supplier to GM for axles.  I seem to recall AAM had a tech note or something from them about diff fluids.  Good luck if I can find it now, but they actually called for an oil change at 500mi on their products due to their initial break-in.  GM calls for that 500mi, but they mention nothing about changing the diff lubes out.
I change the diff's fluids out after 500 miles. Like you stated to get the wear-in materials out and get fresh fluid back in. I know most don't do it.  I've done it now on my last truck and this truck.  I then go 100k.  My last UOA on my 2002 showed all was well at 100k.
    • Anyone have any info about backorder time? It's classic 4th of July hot here in ohio.
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
