I have searched this forum and Googled myself to death and have not found the right words to get any results to suggest which relay or fuse is used disable the amber cab marker lights.
I would like to put a separate relay or simply a switch in series with the fuse to be able to darken all the amber marker (mirrors included if possible).
California says it's illegal to run these cab markers and want to be able to selectively turn them off.
I have not been able to simply identify the relay which controls the markers at dusk, suggesting a relay is in the circuit somewhere and controlled by one of the computers.
If anyone has any information how to do this it would be appreciated.
Thanks,
JT
Can't help you out.
Are you saying CA won't allow the factory installed roof markers?
Yes - in CA, you can't have amber, red or blue lights on top of the cab. as far as I know, mirrors are ok.
can you change the LED to white instead?
I appears that the OP is correct - CA does not allow them.  Trucks built for the CA market have the clearance lights deleted.  I think the easiest way to switch the lights would be to loosen the headliner, cut the hot wires to the lights just under the roof and install a switch between the severed ends.  The switch wire could be long enough to locate the switch in a convenient location on the dash.  It's relatively simple to lower one side of the headliner and reach in to the center of the roof.
Only if you are a conservative!  It is afterall the "People's Republic of California" !
Thanks guys for the reply, but was looking for a solution to turn them off when necessary but not permanently.
It seems odd that there is little reference in the manuals or schematics referencing a fuse or relay for these things.
The come on at dusk when auto is selected so there must be a relay connected to them, or at least a fuse that can be pulled.
In the schematic "Sierra 2500HD Body Builder" there is a reference to a relay KR53 but I do not see this referenced in any fuse/relay box.
Oh well, I will keep digging until I find it.
If you wanted them off all the time, pull the driver A pillar trim and unplug it.  The roof lights are on their own harness.
Here's the schematic:
If you wanted your mirror markers to work correct still and just disable the cab markers, you'd have to control off of pin H3 circuit 709 or down the line of it or those two connector points along circuit 709.  Perhaps you could tie in a switch at the A pillar connector area for the roof marker harness?
Edited by newdude
The two fuses for all of the marker lights (i think minus the mirror markers) are labeled on the inside of the cover of the fuse box under the hood. If you only occasionally want to change whether they operate you could just pull those fuses when you want to disable them.  It will disable the fender flare markers as well as the roof markers. On mine, the roof markers are powered with the left fender markers on one of the two circuits.
Have you thought about just covering them so you don’t eliminate the other markers?
Finally, as I think somebody asked above, why?  If you are an out of state licensed truck they don’t expect you to alter your lights when you enter the state.  Your vehicle was legally sold and licensed in another state with those lights, there is no switch to turn those lights off, and states are required to honor the licensing of visiting vehicles.  It’s like the no front plate thing. You can’t get ticketed in a two plate state for driving a vehicle licensed in a one plate state.
Edited by Another JR
Generally, if you're legal in your home state you're legal anywhere in the nation.  There are some exceptions mostly related to maximum payloads on commercial trucks.  I don't think I'd worry about a truck with clearance lights ever being mistaken for a public safety vehicle.
Yeah, the whole thing about CA equating DOT required roof marker lights to a light bar is absurd. They obviously take themselves seriously because they apparently prohibit sales of vehicles with marker lights. However, the difference is visually obvious. I will occasionally travel into CA with my roof marker equipped truck and don’t plan to worry about it one bit. They won’t ticket you, and if they did it would be thrown out simply by you sending a letter citing the state to state reciprocity. requirement.  In general at least the state police know this and won’t ticket you.
I live in NY and I think its bad.  I just dont know people in CA do it,  I really dont.
@JTRACKER - You could most definitely simply replace the lights with white lights (LED).  Recon Truck Accessories has them - Recon Cab Lights.  I do not know what year your truck is, so you'll have to make the selection accordingly.
Just in case anyone is interested:
CALIFORNIA VEHICLE CODE - VEH
DIVISION 12. EQUIPMENT OF VEHICLES [24000 - 28160]
CHAPTER 5. Other Equipment [27000 - 28160]
ARTICLE 5. Fenders, Ornaments, and Television [27600 - 27607]
27606.
(a) No person shall own or operate a motor vehicle which is equipped with a light bar, or facsimile thereof, to resemble a motor vehicle used by a peace officer or traffic officer while on duty within that jurisdiction for the primary purpose of enforcing Division 10 (commencing with Section 20000) or Division 11 (commencing with Section 21000) pursuant to Section 40800.
(b) For purposes of this section the following definitions apply:
(1) A “light bar” means any light or device affixed to or mounted upon the roof of a vehicle and extending the width of the roof, or a substantial portion thereof, which emits amber, red, or blue, or any combination of those lights.
(2) A “facsimile of a light bar” is any device designed or contrived to resemble a light bar regardless of the degree of light emission or lack thereof. - Not sure if this is a catchall.
(c) This section shall not apply to a vehicle, if all of the following conditions are satisfied:
(1) The vehicle is possessed by a federal, state, or local historical society or museum that is open to the public.
(2) The vehicle is secured from unauthorized operation.
(3) The vehicle is not operated on any public road or highway, unless one of the following applies:
(A) The vehicle is being operated within a temporary street closure for the purposes of celebrations, parades, local special events, and other purposes when the operation is approved by local authorities having jurisdiction over the street closure.
(B) The vehicle is of a model year of at least twenty-five years prior to the year of operation.
Edited by RugbyRef
Based on that definition posted, I don't know of anyone who has mistaken roof marker lights for a police-style light bar.  The roof markers do not meet the definition of "extending the width of the roof, or a substantial portion thereof" - they're just 5 small lights.  Nor is it a facsimile of a police-style light bar.  No one mistakes them as a police-style light bar on a vehicle that requires them.  If they're 100% legal on a dually that requires them, how are they illegal on a SRW truck?
Yeah I agree.  I think people are mistaken what the definition says.  There are yellow bars out there,  tow truck, plows etc.  The cab lights are not a bar and do not take a majority of the roof.  I dont think this thinking is true.  GM sells a lot of vehicles to CA, and would make sure of this..
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
