Well I liked your posts more than a teenage girl likes Taylor Swift, but the beers will need to wait until I am in TX next.  :)
  • Haha 1
  • 8 months later...
This is exactly what I have been looking for. Can you provide a wiring diagram for this modification. I plan to install this mod and some of your description is hard to follow. I would appreciate any help you can provide.
20 minutes ago, Timothy Lee said:
I DEVELOPED THE ATTACHED WIRING DIAGRAM BASED ON YOR DESCRIPTION .  CAN YOU VERIFY THIS IS CORRECT?
This is correct, here are the connector end views so you know where the pins are.
image.thumb.png.4365b1f69c129fe1c74f4744d2cd376c.pngimage.thumb.png.8e989c9b4f1936d989e63670203730b6.png
image.thumb.png.5974afe60fd9547cf8436e7ef154ff64.pngimage.thumb.png.d6498755a7f4094df634c3fca04571ac.png
Thanks. Do you have driver door switch connector view?Also where did you find the connector info. A couple of other items are the door switch you identify is not the same one I purchased.  Yours had only two window switches where mine has 4. I would also like to know how you were able to get the puddle/bubble light working.  The mirrors i purchased also have the turn signal light do you have any info on how to make them work. Thanks again for your assistance.  I know there are quite a few people that would love to have this information. We need to find a way to get it out to the masses.
Aaaaaaaaayush,
I really need help. I am in the middle of the installation with everything apart and have every thing wired up but it does not work.  Even the lock/unlock from my key fob does not work. The only thing in this setup that may be incorrect is the switch. But i would think the remote lock unlock should work even if the switch is not correct or not wired. I did not purchase the same door switch as you because the one you specified was for 2 windows only and I have 4. I purchased one that had 4 window switches but it does not work with the mirrors.  Looking at the pin arrangement I can see it is different from the original. Can you provide a switch with 4 window switches and the mirror switch that has the pin setup in the attached picture. Obviously it would need to have the 12 and 22 pins this witch does not.
The door switches communicate using a canbus or GM LAN connection. When i changed my switch it did not work, not a single function. I tried many different things including soldering wires to the pad for the mirror fold button, but was not able to make a relay circuit that stayed on long enough to fold or unfold the mirrors. I did give up on the door switch and put my old one back.
Check the basics first, make sure you have 12v power. Put a 12v light or a multi meter on the door lock supply you are using from the BCM and make sure you're getting power when pressing lock and unlock, also check the mirrors, using a 12v supply power the motors directly make sure they are actuating.
I just tried to call. I did check continuity for all the wires will check mirror. Not sure how to verify 12 volts from BCM.
Oh man Aaaaaaaayush!! This is the post I've been looking for to give me hope that I can add power folding to my 2020 Trail Boss LT. If you have a minute, I have a couple questions about your install:
1) Mirrors fold in and out only from key fob activation, you're not using the panel button?
2) Does the heating and all other controls still work without issue?
3) Were you able to get the perimeter lighting working or did you already have the safety package that enabled it? If you didn't have the package previously, did you do anything special to get that lighting to work?
4) Does the blind spot indicator need anything additional to work, or is that all built into the mirror?
I never even thought about using a separate power fold controller. I wonder if the aux button panel I've seen some people install would be able to activate the fold/unfold function instead of the door panel one. Thank you for your post, as I won't have to figure out how to do the memory seats now (hopefully).
Dave
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
    • Well one of our most reliable vehicles was sold yesterday. The first and only I gave for free to a grandkid. If they got skin in the game they take care of it. My wife bought new. Five years later my daughter got it to use. We got it back and gave it to our grandson after graduation. He did zero maintenance just oil changes. When the AC quit he drove his mother’s car rather than get it fixed. Instead he just bought a beater and sold the Elantra.
    • I usually do as well or better than the sticker for mileage. Usually better going west than east. North then South. Wind makes a difference. I’m not usually a conspiracy theorist. But it did dawn on me I’m going by the vehicle calculation. Now that would be interesting.
