I know some folks who ordered AVS shields by model and paint code and they don't fit or color match. Not sure about Weather Tech or the others.
Clear paint protection film (PPF) would be much classier on a Denali.
Edited by newdude
  • Thanks 1
I don't get why they are still called bug shields. Aren't they just for protecting the paint on the edge of the hood?
I'd second the PPF. I kinda wish I would have installed that when mine was new. Now my leading edge is full of little paint chips. GM uses the thinnest coat of paint possible to hold its color.
What are future plans with the truck though, if it's just a daily driver ,I'm sure it would be fine, but if the Denali is known for that issue wouldn't hurt to be proactive. Seems like AVS has quite a few that would compliment the front end of your truck too.
I think you meant "EPA".
One mustan't dirty the Kings air.
It has nothing to do with the EPA.  It's purely on GM for using the cheapest, thinnest paint they can get away with.  GM got smart and added the rock chip paint at the bottom of the fenders.  Now they need to put something more resilient on the fronts where rock chips happen frequently.
I would agree except its not just GM that has this paint issue.  Its most all of the major US automakers.  They are all painting thin because cutting costs, weight and EPA regulations (which have changed paint composition over the years).
Edited by newdude
The EPA made everybody switch to non-hazardous paints.  They didn't make them paint it thinner.  That's on the OEMs.
I put an AVS aero skin on my truck and wife’s new Traverse. Love them. They lay flat into the hood instead of sticking up like a bug shield. It Protects the front edge of the hood. I like it too because it gives it alittle different look as well.
2 hours ago, shakenfake said:
Yeah non-hazardous paint is thinner...
Yeah right. The EPA made GM use crappy paint and told them they could only use one coat. Lol.
What’s the EPA requirement for orange peel?  Because this is the first truck I’ve had in a while that doesn’t have any. But It’s my third truck with this new environmentally friendly paint. GM might not be in compliance.
Edited by TxTruckMan
Orange peel, mine (2021) has a metric ****ton. What’s orange peel have to do with any epa requirement?
Nothing.  Just like paint quality and thickness.
    DaleB
    DaleB
  • Who's Online   6 Members, 0 Anonymous, 1,391 Guests (See full list)
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
