Well this is rather annoying. Bought a 2016 Silverado with about 40,000 miles on it just a couple years ago. 84,000 miles on it now and just got a call from the dealer that the reason why it won't shift, revving, jumping and going into limp mode is because it needs a new transmission.
For only $7,500 I can get a new transmission with a 3yr, 100,000 mile warranty on it.
9 minutes ago, diyer2 said:
6 speed 8 speed.
No service history?
6 speed.
Service history I typically followed the recommended 2016 silverado schedule. Oil changed every 3,000 miles and tires rotated - air and cabin filter was changed about every other oil change. Changed the brake and transmission fluid at 46,000.
JMBX converters are junk. When they grenade so does the gearbox.
https://www.sonnax.com/tech_resources/846-transmission-report-6l80-6l90-transmission-tech-advisory-consider-an-updated-converter-in-your-next-rebuild
First paragraph page 2.
Your tech will balk and they will threaten to deny the warranty on the new transmission. So most people buckle under and use the same parts that failed the first time hoping for a different result. You know what that is the definition of, right?
BTW the Reman is just as good a a new one and several thousand cheaper.
BTW a 3 year 100K warranty? Most people cover about 12K a year. They feel pretty safe with giving the illusion of reliable without actually delivering on it very often.
Ask how many 6L80E failures there are when mounted behind the 4.3 V6. (next to none)
They don't use the JMBX converter 😉
And no, the V6 unit will not fit or work with the V8's
@Grumpy Bear - So what's the actual part(s) and part number(s) that I need to have them add to this expensive bill already to ensure this doesn't happen again in 80,000 miles?
try and get the 6 bolt stock converter for a 2500 truck using the 6l90, direct swap, no I dont have a part number but its posted on a few youtube videos doing this upgrade
This is good.
Well just had the truck towed from the dealer over to a local mechanic who's going to throw in a rebuilt Jasper transmission.
I'm going to call around tomorrow about getting a 6L90 torque converter for the new rebuild.
Any other upgrades I should due to try to avoid this issue that is plaguing GM's?
  • Sad 1
Remove the transmission thermostat on the feed/return line that bolt to the side of the transmission. That will cool the temps down by 30-40 degrees at a minimum.
A tune on the transmission by someone that knows what they are doing would help a ton too. Changing the shift mph and the lock up speeds to keep the converter from working as much. From the factory it will be on in gears 2-6 and when I tune them I change it for gears 5th and 6th only.
Wouldn't I be better off moving the thermostat to inside the came so it could benefit from the A/C?
No, just remove it completely so the transmission fluid is always flowing through the cooler.
Search  "flip the pill"
A bunch of us guys on here have done it. It runs 30-40 degrees cooler. It's free too .
    • Yes.   Yes.   We might be intermingling ideas with the term 'severity', in one of my past vehicles it could pull up DTC via the vehicles own user interface, at any given time when one would do this there would be an assortment of codes that were 'trivial' including 'communication' issues. This would generate a bunch of, potentially false alerts or some many that they would get ignored. Which you mentioned earlier.    You also mention several things that might be redundant with the vehicles own systems or indicators: The truck has an oil pressure gauge, monitoring it via this other system wouldn't be a priority except in comparison to other values or if there is an actual oil pressure problem.   Same thing for miss-fires or other problems, the MIL already signals the operator to an issue...   ...to the point about what one wants to see first, if there is a miss fire detected, I want to see miss fire counts or fuel trims first, if I have an oil pressure problem I want to see the oil pressure first. So, perhaps the 'systems' that are showing abnormalities are what gets displayed first.   I think your device is what connects at the OBD port, ease of use for the consumer, it could still have a 'pass-through' port for a second scanner, computer, etc.   Yes.   Based on my comment above, if an error appears, the report would be more specific to the system having an error.
    • Saturday 87 was 2.98 at the local meijer when I filled up my car with 93.
    • I like the idea.  I thought about putting a deposit a few years ago when they first dropped.  I still want to drive one and have inquired about doing this with them, like a ride and drive event they said they are coming but it hasnt happened even with them built in Indiana.
    • That's a tough spot to be in, I personally would question spending 1/2 the book value on a repair vs. selling it as-is.    Presuming you own it out right, sell it for 10k and have a down payment for a replacement truck, or spend 10k on the one you already have...   I still think there is a cheaper transmission out there via recyclers, aftermarket or rebuild. (Cheaper than 5k for the unit)
    • Sadly, there's a drought of good 92-95 4.3 cars at junkyards in the area otherwise I would have gone fishing for parts. Not that they don't come up, there's just nothing good in the yards right now.   I tore into the intake yesterday evening, easier than I thought, and I might have this problem licked for cheap. Two of the intake studs came up with the bolt on removal, no big deal but that's why it looks funny with studs only on one side.   There's pooled gas on both sides of the plenum. Highlights boxed in green. Picture-right side has an obviously split pressure line from rubbing on the #5 injector nylon line. #5's line is worn in that spot but not all the way through. Passenger side intake (picture left), not sure, but I think the pressure regulator is hosed. Rebuilt spiders don't come with the pressure and return hoses so I'll need to replace those no matter what. A pressure regulator is $30 so I'll try that and if I end up having to swap the whole spider, it was $30. I'll be grinning ear to ear if that's all I need.   Parts arrive Tuesday.   Sure enough the shop was here before. That's a new gasket. Vacuum lines and wiring are a tangled mess, I sorted that out last night as well. Spent about an hour just picking up general slack and shoddy reassembly around the engine bay. Cheek-pokered the battery tray, got it all cleaned up. Sometimes things just need a little elbow grease and a few minutes of time to be right again.
