I have a 2020 Denali with the 22” tires. To say I am disappointed in the performance of the tires would be an understatement. It has trouble coping with 2” of snow on a slight slope. It now has 3900 miles on it and with winter coming on I don’t want to go through another winter with these junk tires. I had a 2000 Sonoma highrider with 15” x 33 BFGs and never worried about the weather. The truck isn’t leveled which I think may limit my choices. I don’t believe I can put BFGs on the 22”s without doing some drastic lift. I am seriously considering a leveling kit but not sure what I should go with.  I am also considering 18” wheels so I could go with a decent tire such as BFG KOs. Any suggestions or help is welcome as I am basically new to the Sierra. Thank you.
On my Chev I have a set of winter tires/rims (18") that I put on for the winter. Living at 7000' and driving in the mountains it makes a huge difference. I agree the factory 22" tires are not very good in the snow.
Jay
Get a set of takeoffs and put some snows on them.  You won't trash your nice wheels and you can just swap them on and off before and after winter.
Finding 17"s or 18"s should be pretty easy from a 2019+up new body truck.  TrailBoss/AT4 would make a good option for takeoffs as many of them have Goodyear Wrangler Duratracs already on them.
Your closest match for the speedo without going to some big honking tire would be 275/70R17, 275/65R18 and 275/70R18.
Its pretty clear from the tread on those 22" that they are a 3 season tire.
ALSO...stock 275/50R22 tires are 33" diameter, so a 33" tire on any stock wheel size should fit, so long as its not too much wider.  275 wide is a sure fit, you might be able to go 285 wide on stock wheels either 17, 18 or 20 inch.
Edited by newdude
Michelin makes the Defender LTX in that size, they are a great tire for all year round use.
If your truck came with Michelin Premier LTX's they are pure garbage in my eyes. They are a super nice ride but that's all you get, they spin in the wet with enough power and suck balls in the snow.
My other suggesting for a stock size tire for the 22's are the Pirelli Scorpion Verde AS Plus2 or 3, they are good all around tires too.
I find it interesting that All Terrain tire options are limited for these trucks.  The short sidewall must make the manufacturers  nervous. Having said that, there are quite a few 22" wheels delivered on these trucks, so you'd think there would be more options.
BFG does have a 22" AT tire, it's available in 33X12.5R22.  However I don't think there's 12.5" available for tire width on these trucks.  I'd very much like to be proved wrong.  I'd like to see pics of a 33X12.5R22 on a stock level, if anyone has done that.
Nitto 285/55r22 options that fit are available, for a more AT stance than the Michelin Defender. I've also read that the Nitto 305/45r22 fits stock, as well
There aren't many AT options because a low profile AT tire on 22" wheels makes zero sense.  22" wheels usually get a street tire.  There are many options for those.
The OP started this with a complaint about snow performance. The issue with the 22" street tires in this case is the snow performance.  I don't think many on this forum would go serious off-roading with 22's.  Low profile 22's with an aggressive tread make more sense in a snow environment.  There are *not* many options for those.
Thanks a lot for the input. I am thinking about going with a set for the winter and thinking about takeoffs. Really not sure if they did anything with the brakes on a 22” truck that would hurt me if I went down to an 18” or 20”from an AT4, I don’t want to run spacers.  Sounds like I’d be ok.
CamGTP - the tires are the Bridgestone Alenza and it sounds like they are as bad or maybe worse than the Michelins you mentioned.
One other question - when you swap tires/wheels, does the sensors automatically sync with the computer or do I have to invest in an overpriced tpms tool? So far the dealership has been covering the maintenance but I’ll be doing it next oil change which means tire rotation.
Thanks in advance.
You have to program the sensor.
The TPMS tool is like $14 on amazon and they work great.
I have 285/55/r22 Nitto ridge Grapplers on my stock 22” wheel with spacers and a 3.5 inch lift and I still had to modify the inner fender and the mud guards for them to fit. I was planning on going with 285/50/r22 (I would still need to do modifications with this size as well) but there were only 2 AT tire options worth purchasing in that size. I did a ton of research before my lift and tire purchase and what I learned is not all tire manufacturers have the same exact sized tire even tho they say “285/55/r22”. They will range from 33.5”- 34.5”. That 1 inch may seem small but it’s the difference between your tire clearing or rubbing in places it should not touch. 285/55 and 285/50 from my experience will not fit a stock height Denali. (I own a 2021 Denali 1500)
I agree with the Michelin Defender LTX, they are great in winter conditions.
Thanks in advance.
I think the spare under your truck will be a 17" rim -- which would answer your brake size concern
QAQ Tire, spare 255/80R17SL all-season, blackwall
1 - Included and only available with (QAB) 275/60R20 all-season, blackwall tires.
2 - Included and only available with 20" or 22" wheels and tires.
Standard on Denali
Note 1 = base truck
Note 2 = SLE/Elevation/SLT/AT4
(The other 'spares' used are also on 17" rims.)
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
