I know this is late to the game, but I'm happy to provide some confirmation bias for you 😉
After my 275 55R20 Goodyear SRAs became drag slicks at 35k I put Michelin Defender LTXs on in the same size. Great tire, great traction, great treadwear, no noise, they handle hooligan driving well (think leadfoot launches and taking corners a little hot hahaha).
I believe all Defenders are rated to 70k, I got 81k out of my first set with religious rotation and relatively close tire monitoring. I had a bad habit of running the pressures a tad high so the centers were at 1 or 2/32nds when I replaced them.
My second set I got 67k out of them. Again, had a bad habit of running the pressures a tick high so the centers were wearing faster. The second set I replaced a bit earlier, i think at about 3/32nds just cause I had the tires on hand and I had a fairly long trip coming up (went from Casper WY to Las Vegas 7/4 to 7/9/21).
Third set I'm rotating every 5k miles like I always do and am monitoring tire pressures much closer. Happy to report after 15k miles they are down to 11/32nds (from 12 new) and are even across the board.
Michelin makes the best tires money can buy. Dad has run them on his Suburban, Escalade ESV, DeVille, first DTS, and his current DTS. They ride great, handle great, are quiet, and do great in inclement weather. I've run them on my DeVille and my Silverado and have equally high praise. Tried Goodyears once on my DeVille and they just are not as good of a tire. Same experience with my Silverado. The stock SRA Wranglers were ok but performance plummeted after 35k. Dad had Goodyears as OEM tires on his Escalade and had a tread separation at about 50K.
Yours may be different cause of the different size but I think you will be very happy. Excellent choice!
  • Like 5
Thanks Luke.
Did a couple quick take offs this morning actually on some turns with the road plenty wet enough to were I know for a fact those Bridgestone's consistently lost it. Had a nice smooth take off and good traction.
Tires are still new so we'll see long term but I'm definitely happy right now.
Thank you all once again for the feedback.
-Kenny
Edited by Kenny782
I had the older  Michelin LTX MS2's on my 2002 Silverado, rotated every 6k by Sam's club so they balanced them as well.  They had 75k on them when I sold the truck and were just down to the wear bars.
We have the Defenders on our 2016 Suburban and they are wearing well and still have a ton of tread on them with 40k miles on them.  Same deal, rotate every 6k and keep an eye on pressure.   Great tire all around IMO.
Anyone have any idea why Michelin doesn't have any 3PMSF rated tires that aren't a dedicated snow tire? Ive heard great things about the Michelin Defender LTX's, I'm just curious as to why. Maybe thats a question for another topic.
They just came out with one...  the Agilis has the 3PMSF rating.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
