I have always owned Chevy trucks, and I am looking to purchase a new one-ton gasoline powered pickup for hauling a truck camper.  I have spent a lot of time researching all the major manufacturers:  Ford, GM, and RAM.  Each brand has some advantages as well as disadvantages in terms of technology, reliability, and performance.
The new GM L8T 6.6L engine appears to have some early release issues which, hopefully, GM has/will correct.  I like both the horsepower and available torque from this engine.  I further like the simple, robust design of a cam-in-block truck engine, and I am glad GM did away with AFM for this engine.
Regarding the 6L90 transmission, it's reliable, but both Ram and Ford offer 8 and 10 speed transmissions respectively in their one-ton trucks.  To me, the 6L90 is outdated when compared to the competition.  I do understand Ford has/is having some release issues with the 10R140 transmission which they are now working through the problems.  Ram uses a ZF 8HP75-LCV which has a good track record, and RAM is a strong candidate for my business.
Not only does GM need an updated transmission with the L8T engine, they need to offer a 4.10 rear axle as well.  In my opinion, having a 10 speed transmission and the option of a 4.10 rear axle would help level the playing field.
I like Chevy trucks; so, I am willing to wait to see if GM is going to make a 10 speed transmission available for the 2023 model year.  If not, I may be buying my first non-GM heavy-duty truck.
  • 3 months later...
I'll take this ole bullet proof 6 speed any day. I love it. Imo, this is the very best 2500 gasser on the market by a long shot too. All things considered.
Cast Iron Block, Stainless Crank, Beefed up 6 speed tranny, huge radiator, - and there's no doubt these babies will pull. And the mpg is just outstanding. I get 16-18 when not towing. And, I live in the mountains.
I've rode in the Godzilla. It's speed is impressive. No doubt about it. But, the mpg is just horrendous- no doubt about that either. Nah, I don't want this big boy searching for gears all the time. Gas mileage is good enough imo.
Ya know these trucks are so deceiving- just regular driving would lead one to think she's not that strong....thats until hook her up to tow.....
Edited by MacLaren
I'd like to see a gear to split the ratio between L2 and L3 with converter lock-up.  Also L1 to L2 is a big gap, and could use a gear there.
My experience towing heavy (14,300 lbs to 15,000 lbs) is that the L8T makes it's best power above 4.2K rpms.   I prefer to drive in the 3,500-4,200 rpm range, but below 4,200 rpm under heavy load the engine falls on its face.  That is really limiting with the 6 speed because of the huge gap (almost 1,500 rpm) between L3 and L2.  So it downshifts from about 3,800 rpm to over 5,200 rpm.   I hate to push that high rpms under heavy loads when climbing long grades, and the lack of torque converter lock-up in L2 creates really high transmission temperatures.
The downshift clunk we feel intermittently at low speed between L2 and L1 would be greatly diminished with a gear to split that ratio as well.
Originally I was happy with the 6L90E, but the more I drive (about 14,K miles with just under 30% towing heavy), the more I'd like a strong 8 speed, or even 10 speed if it didn't negatively impact the fuel mileage.
Maybe keep the 6L90E as standard (help keep fleet costs reasonable), and offer the 8 or 10 speed as an option. I'd like to see that option with a rotary PRNDL on the dash, a paddle shift for manual shifting on the steering wheel, a "gear lock" function in tow haul mode to keep the transmission from automatically downshifting under load and an actual gear indicator display on the dash that shows what gear the transmission is actually in.
If the option was under $3K MSRP, I'd order it.  Actually I'd seriously consider trading in my '22 for that.
Thats the dilema I'm in right now.  Wait for a 2024 with the new 10 speed or get a leftover 22/23 with the 6 speed.  I would bet the 10 speed will be an upgrade while the 6 speed will stay in the WT/Pro lineup for fleet buyers.  I just hope it's not a big jump to the transmission and they offer a 4.10.  That might be a good setup and help with the guys who tow towards the top end.  I would be in that category.  I would have flatbed trailers with a GCW of 14-16K.  I know that's diesel territory but I only tow seasonally and live in flat country.  I'm keeping my LML but looking at a second HD to help me when times are busy.
Couple of comments hear desiring 4.10 gear along with 10 speed. Frankly the need for 4.10 is greater now with 6 speed. 10 speed has deeper gearing and the benefits of lower axle ratio are greatly reduced, not to mention poorer mpg of lower gear offsetting potential gains from trans.
Yes.  They should have kept the 4.10 with the 6 speed like they paired them from 15-19.  When I saw GM announce 3.73s I was sure that it was with the 10 speed but then they said 6 speed and it was a WTF moment.
You’re probably right on that, the 3.73 would likely be adequate but I”m sure GM will do something stupid and do like 3.23 with the 10 speed.  We have a Yukon with 3.09’s and a 6 speed and it will downshift on any incline.
At the least have made the 4.10’s an option.  That’s what I had in my 2005 and it worked good even with a 4 speed.
I must be the only person on the planet who dreams of a 6 speed with a third pedal and 4.10 gears in one of these new trucks. Would love to buy a gas dually to replace my 2500hd 6.0 as I will never own a diesel and have sadly been considering a ford 7.3 4.30 dually.
Nothing wrong with a Ford.  That is a darned nice truck! :cheers:
(but the Chevy is better... 😉)
23 minutes ago, MTU Alum said:
It's officially out.  2024 L8T with 10 speed and 3.73 rear axle.
#IworkforGM
As an option or are they only offered in 10 speed?
And it looks like it is the 10L1000.  I figured it would be, the 10L90 is the sister of the Ford 10R80, and Ford does not use that transmission in the Super Duty.
    • How did all that extra get added? AI bot!
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
