I have 2,300 miles on this oil (my first oil change I did at 800mi) truck has 3,100 now and oil still at the full line.
just checked it to see.
Oil light update...
So far the dealer can't find any reason why the oil light came on (besides the obvious, the oil was low) No leaks, plugs are not fouled, PCV is good... they are now working with GMC on next steps
And for the kicker, after 600 miles (I was corrected by the dealer, it's closer to 600 not 800 miles since they changed the oil and started the oil consumption test) the motor was 4 Qts low... WTF
Now there is another issue, why didn't the oil light come on sooner?  AND, why didn't the light come on when I drove it to the dealer last week when it was 4 Qts low...
With this being said, we are scheduled to leave mid March on a cross country trip taking the RV to visit family for 3-4 months. I'm now pushing the dealer to replace the motor b/c I don't trust a "fix"... or what damage might have been done to this motor with less than 20k miles
What a mess
  • Sad 1
8 minutes ago, Rick Schleicher said:
Oil light update...
What a mess
That must be so frustrating, heck it's frustrating to just read about.  I can't imagine having a problem like that.  I hope the dealer corrects it for you because obviously something is very very wrong.  You mentioned the plugs aren't fouled.  That confuses me big time because you would think if your engine is burning that much oil the plugs would look like hell.  I don't know.  I'm just hoping the dealer makes it right by you at the end of the day.  Especially before your big family trip!
Edited by Jettech1
4 quarts low in 600 miles? You need a new engine. That one is definitely defective. Please keep us posted. Sorry you’re dealing with this.
do you notice a ton of smoke while the truck is running?
37 minutes ago, Rick Schleicher said:
Oil light update...
What a mess
The last post was a little confusing. Previous posts seemed to show the oil usage being consistent. If that’s the case it may be normal for your rig. Especially if that’s their position. Your cure would be a different truck. I would run it until the warranty is expired and re access. If you’re 4 qts low in 600 miles well that’s different and a big change.
Hey again,
No smoke on start up or while running, at least nothing that I can see. GMC requested pics of the plugs and to check the PCV, this is where we are at
Originally I reported here and to the dealer, 4.5 qts in 4500 miles from my trip to the Pacific Northwest over 7 weeks back in Sept/Oct. Right after the trip is when the dealer told me this was within spec however, they agreed to the oil consumption test... Fast forward ~3 months and 600 miles after they changed the oil (the start of the oil consumption test), the oil light came on... since it was going to the dealer anyway due to hard shifting at 10-15mph and some pretty loud clunking when going into part from 4 low and backing up the trailer, we started talking about the oil light that came on a few days earlier, today is when they finally drained and measured the oil and report it was 4qts low at 600 miles...
This kinda speaks to things getting worse pretty quickly, they are getting me a rental car tomorrow but so far, not sure what I'm going to do with my trip
As for the hard shifting and the clunking when going into park after backing up in 4 low, they say that is normal, SMH
  • Sad 1
2 minutes ago, Rick Schleicher said:
Hey again,
Just asking is all, but do you think you can lemon law your truck?  I think I would be looking into that by now.
No worries on the questions, I get where you are coming from...
As for lemon law, I have no clue where to start. My concern is this is the first time the dealer has seen the level being down, prior to this it was me telling them it was down 2.5 qts in 4500 miles. So does the lemon law apply here???
Honestly sir I have no idea.  Please research it because it may come in handy in the future for you.
If you’re using that much oil, a new engine is the cure.
I totally agree @KARNUT  That oil consumption with no leaks at all....Has to be going somewhere.  Where is the question because he reports no oil burning.  Excessive blow by perhaps?  If they pull the throttle body off and look into the intake, it could be soaked with oil.  But yet it still would be burning oil when sucked by the intake valves....Very curious.  I would love to be the one tearing that engine down to find out the real problem.  Broken oil rings?  Ummmmm....I don't know but I am curious as hell.
Update:
Per GM, pickup the truck and start the consumption test new... to drive it a full tank, fill it up and immediately return it to the dealership. They sited the service bulletin to go by gals of gas not miles, even though I had a log of my fill-ups, dates, mileage... they said that wasn't enough. Dealer says it's not right but there is nothing they can do
As for the oil light not coming on when 4qts low, the oil light is not to be trusted and per GM, it's the customers responsibility to check the oil level. The dealer said they have a car now with a blown motor due to virtually no oil and the light never came on
As for the tranny, they drove it about 5 miles in all gear patterns and couldn't reproduce anything abnormal - right 5 miles should have done it
Because this is not my daily driver and I work from home... I now have to take it out and just burn a tank of gas just to get it back to them to continue the oil test in an attempt to get something done in time for my trip in 5 weeks
  • Sad 1
13 minutes ago, Rick Schleicher said:
Update:
That would be very annoying at this point. Burning 36gal of gas is going to take awhile when you already know something is wrong. And of course that’s over 100.00 out of your pocket.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
