2018 1500 5.3 CCSB with max trailering 3.42 gears all stock except for DOD disabler in obd2 port.
I drove 1,400 miles over the holidays through the mountains into NYC area with loads of traffic. Got 19.7 over the entire trip according to the dash calculator. It averages 22-24 on trips to and from work and around town/backroads. Pretty good for a full size/v8 with towing gears in my opinion.
Today that all went out the window. I did the sure-cool trans cooler mod install, a 1" front spacer level and tuned it with a diablosport i3 mpg booster and permanently disabled DOD.
My mileage has dropped to 18-19 on the same routes I take that I used to get 22-24. What could of caused this?
1. Could a 1" lift really cause that much aerodynamic drag?
2. Is it the 1" lift causing a mis-alignment and the tires dragging on the pavement a touch more? I haven't had an alignment done yet that comes early next week.
3. The trans temp only got to 104 with the sure-cool because temps have been really cold today/tonight. Is this causing it?
4. Maybe the mpg booster tune isn't as good as it says it is. The truck drives and feels significantly better with the tune installed though.
5. Maybe it' a combo of each mod causing a little fuel mileage decrease each and it adds up?
6. Do these tunes "settle in" once it figures out all the trims?
7. I don't know if it's just me thinking about it more but it does feel like the truck doesn't glide as much when I'm off throttle and not on the brakes.
Edited by scralatchtica824
Number 5.  Yes, the lift will have an effect, the cooler transmission temps possibly some, the tune.  If you want o measure performance, make only one change at a time.  You have three things done at once and performance has suffered.
So the easy thing to do is undo the tune and test.
Ambient temps were also much colder in the NYC area this past weekend, which definitely has an impact for a multitude of reasons.
Without touching anything on the truck, run another tank to get more objective data. One data point does not a trend line make. That said, every mod you’ve made decreases fuel economy.
  • Thanks 1
A few weekends ago I made a trip up north to the cabin, it was -15F outside for most of the day and I struggled to get 17-18mpg in that temp, where as I can get over 21-22 in the summer.
The temp and level are surely a cause for a minor drop but how much is tough to say for sure.
Entirely possible but not to that extent.  .5mpg loss, maybe 1?
This could be a contributor.  As you raise the front, you toe in and that would increase rolling resistance.
This is a possibility as well and possibly a top contributor.  Higher trans temps would allow for less friction in the gearbox.  The ideal move would be the new lower temp GM thermostat, that way it gets warmer in the colder weather, but with its 158F opening temp, still runs cooler in the warmer seasons.
I have no experience with handhelds, only custom tunes.  On my truck with custom dyno tuning, my mileage has been .5mpg compared to stock with a Range DOD.
Yes.  I'd start with flashing it back to stock and re-test.  If you see no change, get the GM updated thermostat for the transmission and re-test.
Truck dropped off for alignment. I'll report back. Haven't made any other changes... yet... I wasn't doing this mod's to necessarily increase mileage... obviously. But the huge hit was surprising. I'll make changes 1 at time from here on out to expose the culprit! Apparently even small lifts cause major issues with alignment specs mainly toe in until they are rectified with an alignment rack and some wrenches. Time will tell!
 I can understand why you are concerned about fuel mileage, but the drop seems to be nominal. To me, fuel mileage means nothing unless its extreme. Like if my mileage cut in half, I would probably take notice, but a few MPG's? Meh - I spend as much money on steaks at the grocery store as I do gasoline. So if for some reason I want to save money, I would probably start with my food budget. But that's just me.
bf5aa5a4dc853e113209e51e7d6964e826399415
  • Haha 2
Oh I totally understand your point of view, and I'm seeing the same sunset as you are. My main concern is the "drag" as the truck feels heavy. Prior it would glide effortless in fact it would gain speed on the highway with any downhill grade. Now it feels like a caliper is dragging. I'm fairly confident it's the mis-alignment causing most of the slow and heavy feeling. I wouldn't of purchased a v8 that weighs 5,500lb's if I wanted great mpg LOL
Somewhere in my build thread I found that my factory 'in spec' alignment while in spec was all over the map within those specs. When I fixed that...WOW!! Largest single gain in mileage from any one enhancement. Worth ever penny I spent so now I check it about once a year and keep it perfect.
I have looked into alignment shops, as I need to have one done after a 2.5" spacer lift front and rear. Firestone offers a one time and a lifetime alignment option. The last time I went there, they rounded off the threads on my tie rod end threads - using a pair of vice grips maybe? I was not happy with the damage. They offered no compensation. Who has the best deal on alignments?
I’ve never had an alignment done ever. My wife’s car gets the same mileage after 10 years. My trucks off road never. My tires would run 90K miles. I ran KOs highest ply I could buy. People are really paranoid or have real bad roads. Maybe drive too fast on bad roads. Almost 50 years driving, really no alignments. I don’t get it.
I hear ya.
In theory, as long as the alignment is set at the factory - and there are no major front end repairs or damage, then the alignment should be fine for ever.
After major front end repairs, I used to do the alignment myself, using a tape measure and hand tools.
Now I just take it in and have it done, but only if its justifiable.
For most, the annual alignments are a complete waste of money. But if you NEED one, then you NEED one.
I use a small volume private shop with an owner I have developed a personal relationship with.
I don't think this is chain store service when you get as picky as I do.
This was my OEM factory alignment.
So much for, "It leaves the factory perfect".
This is the job Deegan's did shortly after I bought it.
2+ MPG difference.
This is the alignment after the Bell/King/Deaver upgrades.
Thrust angle on this one was ZERO as was steer ahead.
Added over 50 yards to the 50 mph coast down distance.
The first check and subsequent adjustments produced 125K miles of tire life on the OEM set
I balance every 10K and rotate every 5K
Check and adjust as needed every time I put my butt in the seat
OEM tires left service with 5/32" left and dead even wear.
They dated out or I would have run them another 25K.
I don't tell people what I think this or that is worth based on my best guess or speculation.
 I base it on RESULTS I get from the work I do.
I don't guess. I measure, adjust and repair/modify as needed. Collect the data and graph it or photograph it.
Tire life was the result of 125K miles of such tweaks.
I pay for this work. I reap the results of that work. I share those results AND THE WORK so that others may PROFIT if they choose to. If you're good with 40 to 60K out of tires and doing full suspension rebuilds every 100K or so then ignore the advice. It cost me nothing. In fact it pays me. My gas savings alone pay for my alignment checks and leave enough left over for pizza and beer. I spend less on rotations and balance than the price of a new set of tires given the extra miles I get from them. I have no interest in ROI. Truck isn't a business and I have no board to answer to.
To the OP. Lift, Aggressive larger tires. Alignment. All MPG Killers. Cold oil affects ALL drivelines. Cold is just winter. Not as big a deal as some think. It is viscosity related but not the largest piece of the pie. I've done my best with a good sharp factory tune and careful setup of suspension and lubricant choices. The difference between my lightest to heaviest oils has been about 1.5 mpg. The difference in equipment life based on viscosity can be multiples. I lean heavy and I run colder than most. Just say'n.
  • Like 3
  • Thanks 1
22-24 is unrealistic I don't care what the onboard readout says.  The ONLY sure method to calculate mileage is by logging miles and fuel used over thousands of miles and then averaging it out.  Taking one snapshot in time and using that as gospel is flawed as these in-vehicle average MPG displays are almost always inaccurate..  If those figures were true (22-24mpg) than GM would be claiming that mileage on the window sticker like on this 2022 Silverado equipped similar to yours.
Edited by elcamino
  • Thanks 1
6 hours ago, Supreme Pizza said:
I hear ya.
I never had front end work either. Most of my trucks went off road. I didn’t keep my trucks past 3 years 150k miles average. I never put over sized tires on  either. Most had tool boxes and fuel tanks. The first 20 years I ran my equipment one ROWs, pipelines mostly. The second 20 years plus selling equipment and training mostly on pipelines. My last truck a used Avalanche I bought with 167K miles recently had tie rods and shocks. That’s it.
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
