Before I tested it I removed the spoiler, cleaned it up and did it right. In theory it could work for the most part. Just hard to do and look good…(especially since it’s my wife’s truck)…..
  • 3 months later...
I recently sealed my cracked, leaking rear slider. First, I took the headliner loose to about the middle of the cab. Then, I removed the spoiler and cleaned the roof and window frame with compressed air, water and then rubbing alcohol. I then applied AC Delco seam sealer along the top of the window frame all across. Let that sit for a day and then put 3M strip caulk on every bolt mounting surface and the 4 bolt holes on the ends. Once the spoiler was in place and nuts and bolts tightened, there was strip caulk sealing each side of every bolt and nut, as well as the 2 alignment pins. We've had some rain since and so far it is holding well. It wasn't a bad ordeal, but not something I want or will do on a regular basis. Too many other other choices of trucks to deal with this poor engineering, design and suppliers. Short of going to a glass company or body shop and having the fixed glass installed, this is good way to try to stop the leak yourself without going to the dealer and the aggravation of such. YMMV.
I think I've got most of it figured out,  but on the 3m strips, do you completely cover the holes in the body then punch the spoiler bolts through it, or form the strips around the holes?
I know this is an old thread but maybe the author still looks at it.  Where did you make the little tape dams at on the window? and did you have to torque the spoiler bolts down? if so do you remember the torque ratings?  Plan on trying this soon hopefully it goes smooth
Tape dam is because the sealer runs.  You don't have to torque them, just nice and snug.   And put sealer around the studs that stick through the holes.
  • 6 months later...
Posted in the leak thread, but I did this method today on my ‘24 Ultimate after it leaked at 1,700 miles. Every penetration under the spoiler got 3m seam sealer as well as all the clips, fasteners, and grommets. This worked like a charm on my ‘23 AT4 as well.
Do you garage your truck at your house? I do and have not yet experienced this on my 24 SLT. I had hoped it was fixed  by now. I'm at about 5K miles, but it has also been one of the driest 6 months on record here in Virginia.
Yes - always garaged at home. Noticed the leak leaving from work after it rained.
  • 4 months later...
Just did this myself. I tried sealing around the spoiler first and it definitely slowed it down, but there was still a slight leak. Not a soaked headliner like it was before the fix but enough I didn't want to leave it. Watched the video on the first paged for the headliner removal. There was two extended mounts for the headliner which I didn't see in the video so thought I was missing something but you just gotta pull a little harder and it'll pull off the glue and you can drop the back half of the headliner. Those were located next to the rear window.
Definitely can do it without pulling the whole thing out. I also used the 3M strip caulk around every hole for the spoiler. Just did it yesterday so letting it sit for the weekend then I'll wash my truck and see what happens. All in all, took me maybe 3-4 hours but let the sealant sit for an hour before pulling the tape out and putting the spoiler back on and putting my truck back together. Didn't take as long as I was expecting.
Edited by Josh_166
Added picture.
  • 3 months later...
So I followed these steps a couple weeks ago. The One difference was butyl rope instead of strip caulk. Thought it was all good. Went through the carwash a couple times and  saw no signs of leaking.
I tried a different wash today and saw a huge wet spot on the driver side and some visible water in the corner. I used to only see some traces on the below window channel.  This was way worse than before.
1 thing that I was concerned about as I was starting was. My truck was backed in the driveway so it was slanted nose down. But I thought the sealant touched both sides of the crease well.
My other thought is I probably cranked on the bolts too much but I had butyl rope on both the studs and bolts.
Wondering which would be more likely to cause the headliner to be more wet than before I tried to fix the leak?
Has anyone here had their slider continue to leak AFTER the TSB sealing by a dealer?  Fighting GM about the cost of a replacement slider now that its leaking again since they've already worked on it once before.
Did you apply sealer to the top of the actual window or just seal the spoiler? You must do it all and don’t spare the sealer. Especially on the very ends. Both of my trucks had minimal sealer on the right side. I actually had to redo the right on my personal truck. The factory had almost none and I didn’t pour (slang) in enough.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 1,921 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
