Well, after ordering my Sierra 1500 with the 3.0l diesel, I actually found one at a dealer, and is currently being shipped.  Will be here Tuesday 1/25.  I have a house in northern VT, and it gets extremely cold there at times.  This past Sunday was -22F.  Reading the manual online, it says DEF freezes at 12F.  What about the fuel gelling?  Is all this negated by just plugging in the block heater?  Is there and additive to the DEF or fuel to resist freezing?  Thanks in advance.
DO NOT ADD ANYTHING TO THE DEF TANK.
The def tank has a heater. You only use def during a regen. Its more likely to be thawed out, before the truck is ready to regen.
I would read up on diesel grades and waxing and fuel treatments. I would carry a spare filter. I would plug in truck if at all possible anything under 25°F. I would find number 1 diesel for below 25. Number 1 and treatment for below zero.
Filter housing is heated by engine coolant. Keeping the coolant warm will dramatically help with the waxing of the filter. These new diesels have glow plugs and start very good at low temps. Some will say you don't need to plug in till zero, because they start so good. Starting is not the reason I plug in at 32 or lower. It's keeping the fuel system warm is.
I call my diesels, EV's during the winter months.
Nothing you can add to the DEF.  The DEF system has 2 heaters, one in the tank, one in the line.
Doesn't hurt to have some anti-gel.  Whatever additives you buy, no metals and no alcohols in them.  GM has some available as well.
Block heater won't work until 0F.  Thermostat control in the cord.
Edited by newdude
I don't argue online, specially with someone like you.
There must be different cords available, cause mine will work anytime they are plugged in.
Now the wifes 15 Yukon is a different story. Had to swap that damn bi-metal coin out of it for a washer.
Hmm.  I guess anything is possible LOL.  I do know that the 6.6 Duramax, the cords are supposed to have one as well, and GM mentions in the manual about using it at 0F or colder.  I wish they'd be more clear on it than they are.
When we were running diesels and working in Oklahoma we didn’t have access to plug in. It got pretty cold. As far as fuel anti gel would be added to the fuel anywhere freezing would be a problem. Never had any problems with gelling. Or starting. I guess these new diesel like gas engines are more sensitive? Or maybe it’s the driver’s.
DEF is used whenever it is running.
Fuel filter housing has a 12v electric heater.
Plugging in does not keep the fuel warm.
All good advice.  As cold as it has been and I'm on a bunch of FB groups for diesels and I'm not seeing much in the way of DEF freezing.  But like stated, do not add anything to it.
As for the fuel, as long as you find winter blend diesel you should be good.  It isn't like diesel of old that had more wax in it.  If you want to use a fuel anti gel, there are several on the market to try.  AMSOIL as their Diesel All-in-one that works well.
Edited by Black02Silverado
You are absolutely correct. I had a dumb ass attack. Completely gave bad advice on def useage.
PS... I am under the impression if the block heater is producing heat long enough, the fuel in the pump, injectors, rails and lines in the engine compartment are above ambient temp. Depending on the wind wiping away the heat.
In my world, feeding livestock in the middle of a cold spell, isn't the time I would want to be messing around changing fuel filters, or dragging something in the shop to unfreeze. Water lines are hard enough the way it is.
I'm glad gm supplies a winter cover on the HD's.
Edited by gemarsh
Added to conversation
Based on society for over the last decade, I suspect it's the driver's
^^^100% correct.
I live in Alaska and haven't had any issues.  Every tank I add Opti-Lube Winter Anti Gel, works great and adds lubrication to the fuel system.  Good so far.
    • So you're saying toss the baby out with the bathwater? @txab posted article was her take on how AI can be used to manipulate pricing as it already does and has been rebuked by the judiciasry in housing. How AI can be and is used to maximize refinery or even Amazon operations all of which are true but because she is who she is; that makes what she says about what is true, false? Is that something akin to Pre-justice aka prejudice?    Look, I'm first in line to approach all information with caution just because we live in a world where people like to lie about someone or something with such a straight face and in such volume that it makes digging to the truth wearisome. Meaning I understand the skepticisms but if I were to toss out everything a person is for a view they hold then my pool of people to draw wisdom from would be non-existent and I'd be forced to reinvent the wheel daily. Not practical.    "Be innocent as a dove but as cautious as a serpent."    Test each word. Every good lie is part truth or no one would believe it. Find the truth in it and reject what isn't.    On this one, AI is being used to do what has been done by hand for hundreds of years already but at such speed, the point of a computer, that it is more easily monetized. This one wasn't that hard a lift.    I wrote a few formulas in a Lotus 123 program decades ago, a series of linked Macros actually, that allowed a daily inventory to be turned into a running P&L and production plan. Something that took three departments a week to assemble now took the time it takes to input the 'daily changes' in inventory. Later that was ungraded to the more powerful Excel program an and integrated with bar code scanning, inventory to supply was done once per shift. It had a huge impact on production scheduling, Seamless interruption flexibility, inventory error reduction, raw materials cost effective utilization and scrap reduction. Huge improvement in the bottom line. I spent months on that and AI could have done it in minutes. So yes, it not only can be used, they would be foolish to not try. The legality, ethics and morality are not the domain of AI. Humans need to keep a reign on it.
    • New to this forum.  Also looking to tune a 6L80 and trying to work out all the issues in my transmission swap.  I have a 6.2 diesel (1983) and have removed the TH-400 and about to put in a 6L80 with a TCM-2600 interface and don't have a clue what I doing after that.  Did you (Leatherneck/RAV3) get your slip resolved? I too hate to spend that kind of money on a tuner that hopefully I will not need too many times although from what steelerdude15 added about the HP Tuner being great for diagnostics would be a plus.  I am also from WNC but below you in Columbus.  Any helo would be greatly appreciated.
    • Sounds like a smart reasonable person with common sense. Bill O’Riley never said he was just a journalist, by the way.
    • It's like saying Bill O'Reilly is "just" a journalist.         Lauren Fix, widely known as "The Car Coach," is a prominent automotive journalist, television personality, and self-identified conservative. She is a frequent contributor to right-leaning networks and platforms, offering commentary that intersects the automotive industry, consumer economics, and conservative political perspectives. [1, 2, 3] Media and Commentary Network Contributions: Fix serves as the National Automotive Correspondent for Newsmax and is a frequent guest on Fox News and Fox Business. Video Platforms: She has contributed to PragerU, where she has hosted videos critiquing government mandates on vehicles. [1, 2, 3] Core Positions Anti-EV Mandates & Fuel Policies: Fix regularly critiques government subsidies and mandates for electric vehicles (EVs), framing them as impractical and burdensome to the average consumer. She advocates for consumer choice and supports traditional internal combustion engine vehicles. [1, 2, 3] Economic Analysis: Her commentary often emphasizes the impacts of fuel prices, inflation, and federal regulations on drivers. [1, 2, 3] Political Alignment: On her public channels, she actively supports deregulation, "drill baby drill" energy policies, and the removal of government restrictions on auto sales and manufacturing. [1, 2] For analysis from Lauren Fix on how consumer automotive choices can align with political leanings:
