Does anybody have access to either AllData or the 2008 Silverado FSM that can confirm the body mount bolt torque?
That number is nowhere in my Haynes manual and the only number I've been able to find in a service manual is 70 ft lbs. Searching online shows a value much lower and that is around 55 ft lbs so I'm hesitant to torque to 70 lbs if that's too much.
The truck is a 2008 Silverado 1500 Crew cab 4wd. Not sure if the radiator mount bushings are more/less that the 6 main body mount bolts either.
This info is from MS3DALE (works for a GM dealer) and is found in the Vehicle Appearance, Care, and Maintenance subforum...About the 10th post down
Quote
Body Mounting Bolt
60 N·m Plus 170 Degrees
44 lb ft Plus 170 Degrees
Edited by dsr611
That's even less than what I had already found online. 44 ft lbs seems really loose for body mount bolts.
Edited by Mossyoakglock
GM service manual shows currenty as follows:
Body mount bolts - Remove any thread sealants on bolts, apply high strength thread sealant (red loctite), torque to 70 ft.lbs/95Nm.
Radiator support nuts - 52 ft.lbs/70Nm.
Radiator support bolts - 52 ft.lbs/70Nm.
Edited by newdude
That's awesome. Thanks!
4 hours ago, dna9656 said:
Great links.  Thanks for sharing.
