Long time viewer first time poster. Picked up a 22 refreshed slt 4x4 Texas edition in pacific blue metallic. Removed the running boards and air dam and replaced the stock tires with the new cooper atp 2’s in the stock size.   Transferred over my backflip x4s from my 21 Silverado and plan to install the sharp truck finishing caps once they come in. Here’s the link to the walk around video: https://m.youtube.com/watch?v=0X6O0v60Bas
Edited by Blue22GMC
Nice truck! Love the interior and new front end.  Are the Tail lights the same as the 19-22s?
Yes, as far as I know everything behind the cab is exactly the same
That new dash is real tempting.
No... stay strong, Jeff. You promised the wife the Denali was going to stick around for a while!
  • Haha 1
 Jeff, do it , Do it.... DO IT! :)
  • Haha 1
3 minutes ago, Low Elevation said:
 New truck looks good. What made you switch to the GMC ?
 Is that some sort of trick question? Well duh he wanted professional grade 😁
Preferred the look of the GMC on the refresh
I really hate that shifter on the center console. Its a friggin truck, why would they do away with the column shifter.  I dont like the interior refresh at all even the dash looks awful.  Looks like some feminist liberal tried to design the truck to look like a ferrari on the inside.
Looks great, congrats. I was in the market but ended up lifting my truck so I’d have a reason to hold on to it for another year. Maybe once they refresh the HDs…..
Any plans to mod? I’m assuming suspension is still the same so should be plenty of options out there.
You are aware that the console shifter is just an option right??
The column shifter is still there on trucks without the full center console.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
