I had a 2019 denali and absolutely hated the seats, I know a lot of people have complained about them.  Anyone that has a 2022 refreshed model, can you tell if they improved the seat comfort at all?
I've been using an AirHawk pillow in my 19 Sierra. Only way I can drive long distance and be comfortable.
I have a 22 refresh LT Trail Boss with the leather buckets and they are comfortable to me.
I sure hope they did change some.  I really love the design of these trucks and with the new OS being Google, if the seats are better really thinking about giving them another try. I just don't really like ram trucks that much, I've had to lemon law fords and am super disappointed with the new tundra.
What did you replace it with?
Mines a '21 denali.
Seat bottom height adjustments for front and rear of seat bottom are separate.
Took a lot of fiddling with the front and rear rear height adjustments to get the combination of tilt and height that would work for me.
Truck has 2 drivers that like much different positions.
It would be a nightmare without the memory settings.
The 2014-2020 generation seats are the worst seats ever! I'm in a 2021 Sierra Denali with different design seat and they are ergonomically better but over all marginally better as in they dont hurt like the previous generation. Still too firm. Doesnt look like the seats changed much but the advertising for the massage seat option states they are different and more comfortable. But no one has them yet. Thats what will make me jump also.
Does the refresh have the same style covers and shape as the LTD?
Edited by mafd2
I have a kia stinger, was planning on replacing it with the new tundra as I have had tons of issues with the ford and have horror stories about ram.  Don't think I've ever been as disappointed with a vehicle as the new tundra, so now I'm back looking at these after the refresh.
From everyones pictures they look the same. No one has posted having the new massage, improved seats yet. They are an upgrade and will be available on the refresh. One person posted coming from a '21 to the new refresh that they felt better?? But mentioned not an apple to apple comparison due to the new truck not having ventilated seats...which does compromise comfort due to the bubble wrap type design GM uses incorporated into the seat for ventilation.
Well have to get more information when more people get their refresh.
The seat would not look any different if they made any change it would have been in the foam they used or the moulding method used in making the seat.
GM seemed to really listen to the customers on the new interiors I would think they were also listening to customers about the seats.
I wonder if the part  numbers are the same or not?
I got my Z71 refresh yesterday and I can say the seats are more comfortable than my '19 RST even though they look the same. Passenger said the same.
2022 refresh at4, seats feel exactly the same as my 21 silverado. I had a five hour drive to get my truck...my back felt just as bad on the way back with the new seats as it did driving up in the 21.
    Greg3160
    Greg3160
  • Who's Online   3 Members, 0 Anonymous, 424 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
