6 minutes ago, Grumpy Bear said:
I try to do at least 50 miles. I can make that longer and run the Interstate, I guess. And yes, as fast as I can get the hood up after shutdown. :dunno:
263K. She's tired and wants to take a dirt nap. :(
Did you get any of the RLI 5w-30 when it was on sale?  Maybe try that, heck it might still be on sale.
Is the air filter restricted? Plugs are seeing a lot of oil and fuel might change em out. Both these will drop your fuels dilute 1% or more.
VOA Red Line Euro 5W40 from new plant.
Tis the stuff Raven is on. I bought two cases from the same lot. About 8 oil changes. This is the touchstone.
Major data is very close to the PDS from Phillips. Yea, still a good dose of POE in it. :) Initial OCI's are targeted for 3,750 miles or Mitsubishi's severe schedule.
Grump is this a recent or current formulation?  Looks like it.
Yes, I just had it run out of the bottle of the case I'm using.
  • Thanks 2
Hook that pig up to a pro scanner and operate the EVAP solenoid valve via the scan tool and see if its sticking. As I recall ( LOL) you had it scanned ALONG time ago with your favorite mech/tech. Try again. May really help you.
No need to drive to long to sample, I prefer a cold sample to one that's rushed after a short operation, 50 miles is needless brother.
Found this from my boxes of ancient history : circa 1980
The lab still exists in some form. They do Phillips aviation oil samples. Anyone tried them?
https://laboneinc.com
Edited by customboss
Add info on a lab source
I like the Vice Grip garage oil test. He’s famous for it only needs what it needs.
Thanks. It’s not just the elemental analysis but the additive package in total. Amsoil
is more advanced and not off the shelf.
5 hours ago, VicFirth said:
I just received this from Red Line FYI
That is quite a bit different than the results I got ;(
Is this the Professional Series Line? Or the High Performance Line?
Edited by Grumpy Bear
High Performance.
17 hours ago, VicFirth said:
High Performance.
@VicFirth do us a favor. Send my HP line VOA to your inside guy and ask, "What up" cause I can't get a response from them after 20 years plus now that Grandquist has retired. That far off is way more than difference in equipment.
Yeah unfortunately that was his response what I posted above.  If Dave G. was there I'd be able to find out.  He was the guy that told me some grades of Red Line use up to 40% POE.
I think there was a tweak recently.  The only main difference is the mg level.
There was a 2022 or so FTIR done on the ROC site which showed Noack 4.7% for Red Line 5w30 Euro.  Substantial POE
Edited by VicFirth
  • Thanks 2
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
