Looking to compare the size and fit of the following:
  • DU-HA 10400 open top
  • GMC 84734683 with lid
 Can find any pictures that show the fit of the GMC - the DU-HA looks nice but thinking I may want the hard surface of the lid to put things in when I flip up the seats
TIA
Walmart $163 US
Kojem UnderSeat Storage Box Container System for 2019 2020 2021 2022 Chevrolet Silverado GMC Sierra 1500 2500 HD Replace 84734683 - Walmart.com
Didn't know they sell stuff like this.
BTW, the lid on top is a good idea. It gets you another 4-6" of height to put stuff in with the seat up, I could have used that a few times over the years. Next one in the next truck will have a lid, thanks for the idea.
Tyler
Edited by Amcguy1970
I have the Du-Ha. It is cheap. The box has started to sag forward after being loaded with drinks on our camping trip. You get what you pay for i guess
Edited by James Mead
poor spelling
I have the Du-Ha for Chevrolet & GMC Silverado/Sierra Light Duty Crew Cab - 2019 -2022 & 2020-2022 Heavy Duty Crew Cab - w/Lockable Lid.  No issues
Factory non locking open top, I stuff it full and like it but plan on buying the Tuffy lockbox so I don't get burgled.
Quote
The open top GM one looks smaller than the one with the lid? Found DU-HA dimensions but not the GM covered one - but they look very close in size and are similar price........
Specs for the Tuffy lockbox for underseat 2020 Silverado one
https://tuffyproducts.com/products/chevy-gmc-rear-underseat-lockbox-chevy-gmc-2019-2021-silverado-sierra-1500-19-new-body-style-2020-2021-2500hd-3500hd/?sku=352-01
PSA:
Quick hammer tap will knock the locks through and their "In like Flynn". Don't keep anything in an unattended vehicle especially garage door openers and personal information.  😉
54 minutes ago, It's Tim said:
PSA:
So how do I get in my garage? You mean carry it around everywhere like my keys? Yeah that's a little paranoid. Most break ins in a vehicle are when they are unlocked and also depends on the area. I park in the garage but even those times I can't I just lock my vehicle.
What do I do if I have homelink? Deprogram it each time I get out of the vehicle?
Tyler
  • Haha 1
Jus saying that without a little advance planning a thief could be in your vehicle and through your home before you even suspected an issue.
Scary huh?
Edited by It's Tim
2 hours ago, It's Tim said:
PSA:
It's all about preventative measures and causing the robber to take more time, leave yours unlocked if you wish, I will lock my shiot up and I won't leave my home addy on  my registration or my SS card in my truck either.
Anything can be breached of course.
CHeers
Edited by Robby James
CHeers
That's for sure and now you feel violated 😠.
  • Haha 1
By the lid I mean the plastic lockable GM one:7f054680cd5c9559c8b11a712ae76049.gif.jpeg.c15e435b0c59996f38099ce1095eeb6b.jpeg
vs the DU-HA
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 874 Guests (See full list)
