Range OBD module VS pulsar LT
does anybody know how these 2 products disable  DFM?
I have the range module for my OBD port but it sometimes doesn’t keep DFM off I’ve already tired 2 different ones. It’s just not reliable to keep DFM off for good while installed  in my l84 5.3. I can the see the LEDS flicker all the time so it’s always fighting the signal to keep DFM OFF by design. And clearly sometimes fails
does the pulsar LT actually disable it to the core? When installed. or is it the same idea,  always fighting the computer. Any ideas
The Pulsar intercepts the signal from the computer to the engine, and tells it to stay in 8cyl mode.
Do you mean that the OBD port is losing power or is only a few LEDs turning flickering?
On 10/11/2022 at 5:25 AM, GN2018 said:
You don’t have a friend in a State that you could ship the Diablo to and have that person mail it to you?
Not loosing power from the port.that I know of.
I’m not sure what the lights mean. I just know that their always changing pattern. So I assume it’s constantly sending the signal to keep DFM off.
it’s not a one and done vs a actual tune… I’m hoping the pulsar LT  stops DFM more robustly. Like a tune but without the tune as advertised obviously.
im not a fan of that. I can still sometimes feel the truck changing from v8 to  everything in between every now and then. Not 100% reliable in my experience.. and I tried to 2 new range modules  that were updated. At least with this 5.3 l84 DFM engine.
im going to try and try a pulsar LT for now and later try and get it tuned off permanently with a superchip tuner to anticipate a DFM hard delete.
I had the Range OBDII plug in and it would work a few trips and then I could notice that the DFM was working and when I come to a stop the auto stop/start would be active and I would have to unplug the unit and put it back in. I got annoyed with that after a while and bought the Pulsar LT about a month ago. It was super easy to install and program and it has been working just fine since day one. I recommend the Pulsar LT unit because it works all the time.
  • 3 weeks later...
I ended finding a way to get my ECM unlocked from superchips. And got their tuner I disabled DFM with the tuner. And for sure it’s now OFF permanently. With the range module I was able to notice it would only work half the time I would coast then gas the pedal and I would feel the engine go into v8 very often and then not
Now with this tune off  it’s just off period. instantly v8 feel.
IMO. Those modules are always fighting the signals from the ECM to constantly block “AFM/DFM. It’s not just shut off. And I’ve tried 2 of them updated ones…. Theirs a reason why the LEDS blink back and forth. Maybe it’s just my truck idk. Or DFM is just more complex then AFM.
Tuning it off actually reprograms so DFM doesnt even exist electronically.  At the ECM level. So No signal to block from the beginning.
As a side benefit the transmission now  shifts even better and firmer a whole lot less lag 😁
?? Are you saying superchips reprogrammed your ECM??
7 minutes ago, 11bravoZ71 said:
Yes superchips unlocked my ECM. Then after I got it back from them I was able to tune the truck adjust other settings and disable DFM.
What did you use to tune the truck and adjust settings?
I used the superchips tuner, part number 2847-S. Once you receive it in the mail you fill out a form online with instructions it was VERY easy to do.
Then  I had to ship my  ECM to them to get it unlocked, it’s included in the price of the tuner to get it unlocked. I just had to pay to ship it to them…. they then ship it back really fast on their dime overnight. Then you can use that tuner.
We’ll worth the investment If keeping the truck long term like I plan to. To disable that DFM with a permanent tune. If the motor still fails later from a lifter I’m rebuilding it with a DFM delete kit and will already have the tuned off portion done.
https://www.holley.com/products/tuners_and_programmers/handheld_tuners/parts/2847-S?utm_term=&utm_campaign=Google+Shopping+-+SuperChips+-+Brand&utm_source=google&utm_medium=cpc&hsa_acc=7848552874&hsa_cam=13757689632&hsa_grp=125866783153&hsa_ad=531361842411&hsa_src=g&hsa_tgt=pla-1457925725188&hsa_kw=&hsa_mt=&hsa_net=adwords&hsa_ver=3&gclid=EAIaIQobChMIwZHvtaaG-wIVYQx9Ch2YeQEsEAQYAiABEgLmyPD_BwE
Edited by 11bravoZ71
Thanks for the info. I didn't think the ECM's on these trucks could be unlocked.
On 10/12/2022 at 2:34 PM, 11bravoZ71 said:
Has anybody done a hard delete+tune off  on a DFM 5.3 or 6.2
I see these guys made a kit recently… hopefully people start finding ways to do it,  to get data on longevity.
https://www.michiganmotorsports.com/camshafts-michigan-motorsports/dod-afm-delete-kits/2019-l84-5-3-dfm-lifter-delete-kit-dod-afm-5-3l-gen-v-kit/
I know a local guy (alberta, canada) has done it as my buddy tuned his truck. No idea how its running though.
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
    • There's a bunch of tea leaves that you've read, but in any case the delayed timing is unusual. Not sure how that relates to the rich at idle vs. 'normal' while driving.   If you're in this deep, might be worth investigating, and re-learning the sensor. What have you got to lose? Plus, it properly fixes the timing cover leak.
    • The only problem I have seen this cause is longer crank times.
    • Injector is being sent off today for rebuild and I estimate I'll have it back in 10 days or so.   It may not be the injector...of course...now that I've torn down the intake again. But, let's rule out the injector and replace those spider legs that have been almost rubbed through.   The truck has always had negative timing and I'm reading "normal" timing at warm idle should be +16 or so. I'm negative 16 to 25 or more, and it's always been like that since I bought it.   A light turned on upstairs last night in the old noggin. Rare, I know...   This will be wild, if it turns out to be the cause!   In 2001, according to the old service documentation, the muffler was replaced. Why? I have no idea, it wouldn't have been rusted through by then. But they did a crappy job.   In 2019, another shop replaced it and noted the prior install was poorly done on the work order. "Exhaust system vibrates on crossmember". Except...I guess they just left it be? I believe the husband, the couple who were original owners, had passed by then. Maybe she said it's just not worth it to have the exhaust system fixed and declined repairs. Very few miles were driven between 2019 and 2025.   The exhaust system vibrates heavily on the crossmember and you can feel it and REALLY hear it, even today. Not always, but at idle, it gets going pretty good sometimes.   What if....   ....What if that's enough to trigger one or both of the knock sensors? Could it be tricking the sensors into sensing knock, so it's pulling timing aggressively? Pulling timing heavily means it's firing after the piston reaches full height which means incomplete burn which means the O2 sensor is sensing a rich condition, which means I've been chasing my tail, and what I thought was an inconsequential problem (janky exhaust) has been THE issue for this truck for 25 solid years?   That would be wild. Maybe it IS wild.   The service documentation thereafter, for years, shows visits for rough idle, replacing O2's, replacing the cat, replacing plugs and wires, a misfire condition, like they could never solve the issue. The injector has been replaced 4 times in 80k miles, that's just crazy.   The secondary theory....   The engine has clearly had a leak at the front seal for a very long time (the greasy trench...). I think the truck changed hands quickly ~2025 because there's Napa receipts from someone I don't recognize in the ownership history. They apparently replaced the timing cover seal, and they did a terrible job. There's RTV smeared all over and the leak I had reduced to a weep by snugging the front oil pan bolts is now a leak again.   HOWEVER....I read about replacing the crankshaft position sensor. Any time the ckp sensor is disturbed or timing cover is removed, the truck requires relearning, and that can only be done through a bi-directional scan tool. Skippy with the RTV probably didn't do the relearn procedure is my guess. His scan tool is lost in a pile of RTV goo somewhere.   So, it's very possible the sensor has been disturbed and the truck is just running on the old learn data but not setting a code for anything. The distributor has since been replaced and so has the camshaft position sensor, so all bets are off for that thing.   In the theme of one step forward, two steps back, I returned the accumulator for the AC. The gal I've been working with at O'Really's has been great. She refunded it under manufacturer's defect and we compared it to the replacement I ordered, and sure enough, the replacement is machined very differently (and a gauge actually fits on it!).   Got it home, installed it, started vacuuming it down.... and I couldn't get good vacuum.   The high side service port, where I replaced the old GM ball valve suspecting that was a source of the previous leak....well, I've clearly exposed whatever pre-existing crack in the line where the service port is welded, and made it much worse. Blessing in disguise? Except there goes another $25, now I'm waiting for a replacement AC line.   In 10-ish days ALL the parts will be here. Rebuilt injector, new exhaust system, new cat, new high pressure AC line.   Oh, did I mention the squeaking ISN'T coming from the AC pump? The truck still squeaks when started, and there were words after I started it with the new AC pump installed. But, there was more to replacing the AC pump for just a squeak. A truck with good working AC is something of value, for the comfort alone.   I've ordered a new harmonic balancer because, 30 years is a good run for one of those. Rule it out. The squeak may be something more sinister, though. I'm worried about that ckp sensor and if it was shimmed correctly, or if the timing set was installed correctly. The squeak may be coming from UNDER the timing cover.   At this point, once I get it put back together, I'm thinking I'll take a 50 mile victory lap and then promptly put it up for sale. This truck is cursed. Betty, from beyond the grave, doesn't want anyone messing with her Blazer. Or maybe she's getting revenge for 30 years of shop visits with that thing.
