2022 2500 Chevy gasser......I know this topic has been discussed before, and I know GM said all is good. BUT, I never had that terrible sound until I had the oil changed at the dealer at 2500 miles.  Ever since then, every time I do a cold start I hear this, of what I think, is the timing chain just rattling like heck for a second.  I've checked the oil, it's fine, the dealer of course used a GM oil filter.  There has to be a way to fix this.  I hate it and want to get rid of it, the sound that is....I love the gas engine....best engine ever.  I just want it to not make a horrific noise on start up like it did before I had the oil changed for the first time.  Any ideas how to solve that?
My 23 makes the same noise.  Sounds like it’s coming from under the cab?  No idea what it is.  Hopefully its not like the gawd awful noise my 3.5 EcoBoost used to make, but that was cam phasers.
My 6.6 gas makes the same noise on cold starts. I explain it the same way, sounds like a timing chain rattle. I was at the dealer last week for an oil change and I brought it up but of course they didn't know what I was talking about. I couldn't leave it there for several hours for them to do a cold start to reproduce it.
I had the 3.5 Ecoboost in our 2019 Explorer Sport and never had a problem or noise out of it.  Now, I did my own oil changes and used Mobil 1 with the factory oil filter.
I'm trying to figure this out...that 6.6L gasser is to die for.  I absolutely love it....But why on earth does it make that noise?  I've read that the oil filter check valve to keep it primed isn't working...I call BS on that theory.  Something changed drastically when my first oil change was done at 2500 miles...  Now what is different?  The only thing different is oil and filter.  Nothing else.  Unless GM put in some kind of additive to their oil......hmmmm...  edit again...I bet GM was using a thicker based oil.  Like a 0 or a 5W-40.....That would make sense for initial break in for an engine that is robust as this one is.
Edited by Jettech1
I don't know. I am friends with the service manager at the dealer. I sat down with him in his office and he looked it up in the system to see if he could find any kind of bulletins describing the noise but he could not. I guess I'm just not going to worry about it for now. If it for some reason gets worse, than I will make plans to leave it with them so they can cold start it.
I'll figure this out and let you all know.  That's what I do.....lol...be well....
It's not the oil filter check valve, it's the oil pump itself. It bleeds back and gets air in the veins of the pump. The sound is the pump shoving that air through itself while is sucks up oil to send through the engine.
It does no harm to anything and these oil pumps have been doing it since 2014 when the LT engines came out. It's worse if you park on the incline and anything below like 40 degrees outside.
If you bought the truck in the summer, you'd never hear it.
It's almost always hot here. I hear it everyday.
I did buy it at the end of August which is hot as hell here in Atlanta.  But it immediately started making the noise when I had the oil changed early October.  It never made a peep until then....
So if that's the case, why did it not do it before I had the first oil change?  That's what has me scratching my head here...it's like, what the hell happened with just an oil change....
Make sure that a PF63 filter is on there and that they used 5-30 oil and not 0-20. I work on the line at a GMC-Buick dealer and can tell you that the oil changes are usually done by the newest inexperienced ****** heads that they can find. Mistakes happen every day. I would not let half of them put air in a bicycle tire. Just something to check.
Pray tell how this can be accomplished, perhaps with the Bill Nye science set? 😉
Is the oil level good?  On your paperwork, is there a p/n of the oil used?  Did they install a PF-63 filter?
Can you give us a video of a cold start?
Without hearing it I'm leaning towards normal.  Its the oil pump that is making the noise.
14-06-04-004H: Various Engine Noises During Cold Start and Warm Engine Operation - (May 12, 2022)
Oil Pump Cold Start Rrrrp or Rasp
The oil pump design has changed from a gerotor gear type pump to a two-stage vane type pump for fuel economy reasons. At temperatures at or below 0°C (32°F), or when the engine has been sitting for a few hours, it is possible to have air enter the pump through normal oil drain back. Upon startup, the owner may hear a short “Rrrrp” or “Rasp” coming from the front of the engine. It is most often heard during a remote start.
There is nothing wrong with the oil pump or oil system. No repairs should be attempted for this condition.
Edited by newdude
  • Thanks 4
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
